Can I be one of the first to get in line for one?
Depending on the price of course
Have you considered using an ER20 collet?
Thank You.
The next part of this build, was to inspect the Bearings as the customer had used them, What I found was not good, one of the Bearings cage was cracked & the other had slight damage, So I disassembled the bearings, to take a better look, All the main Bearing surfaces were ok, so the only way to save them was to make some new cages for them
Some photos of the new Bearing Cages & reassembled Bearings
Mactec54
Are you making these cages your self? What is the material of cage.. Why not you are using ready made bearings?
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
Khalid
The Bearings were already made, But the Cages had been Damaged, So to Save the Bearings I made some new Cages
The Material is a special Engineered Material, which is better than the original Material
It was a custom blend of (3) different Materials that I had over from another job, I work with a lot of special plastics
in injection molding & machining
Could I have made the complete Bearing, or a custom Bearing, Yes I have made custom bearings before
If you have the time & someone is paying for it, anything is possible
Mactec54
Drools
Yes any of the ER sizes could be used to build a spindle
Mactec54
Mactec..You are incredible
I agree with Khalid. Mactec, you are an inspiration to us all.
Great work. Hope all is well!
Add me to the list of people interested in one of these!
Very Vey Nice!! Cant wait to see more.
I bet you could buy an HSD for less than all that time is worth.
Outstanding work, as usual.
Yeah +one more agreeing with Khalid's point!
You know the guy's a pro when he just "makes" some more bearing cages...
Khalid
kiwibrick
tskguy
ger21
RomanLini
Thank you all for your support & comments
There is a special thanks go out to spoiledbrat, I'm glad I could make you feel that way considering the situation you are in
spoiledbrat is a Black Hawk Pilot/Test Pilot & is on his 4th or 5th 12 month deployment
Mactec54
So do you want to be spindle specialist? You have good skill in bearing and your thread in spindle amaze people here..
Before assembly all the spacers, end caps were checked to see if all surfaces were flat & parallel
There was also a lubrication port added to the body
It was then assembled
Mactec54
asuratman
No I'm not a spindle specialist, Just trying to show what can be done to build a simple spindle, That DIY guys could do & use
Mactec54
I'm just a hobby machinist, but would like to try something like this for my CNC router. What special tooling/machining was required to be able to machine the collet holder? I'm guessing it was hardened steel? I've never done anything harder than mild steel on my mill drill or lathe. (I did drill some stainless steel once, and I just put a dent in it and turned it bright orange!)
I'd also love to see your set up for regrinding the collet on the finished spindle. I bought a cheap chinese spindle (not through ebay - stupid!) which has terrible runout. I'd like to try and correct it before scrapping it.
I will really like to see a video of:
1- Dial indicator readings on tool tip.
2- Cutting /Machining of something with this spindle.
Regards
Khalid
The video of this one will be up to the customer
The spindle Taper when finished will have Zero run-out
When it is complete, The taper will be reground with the spindle completely assembled
It then depends on how good the collets & tooling you use, This will determine how much run-out you will have
Mactec54
To assemble the Spindle & lock the End Caps in Place, A Pin Wrench was made, to torque the the front & rear End Caps
The front End Cap holds the outer race of the Bearings tight into the Bearing pocket,This is part of the preloading of the Bearings
The rear End Cap has a Smalley Wave Spring in front of it, for thermal expansion of the Spindle
Spindle Mounts also in place
Mactec54
Fantastic, one more question, how many hours have you put into this project? I'm thinking it is just about done now.
Thank You.
