587,210 active members*
3,046 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > J325 with BEI Encoders reused in retrofit
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Dec 2013
    5714
    Re: J325 with BEI Encoders reused in retrofit
    Quote Originally Posted by lavrgs View Post
    I'm wondering if CAT 5 cable would bo ok to use...
    It would work, but make sure you use stranded CAT5, but it's not normally shielded which is desirable. On the other hand, a line driver output (differential quadrature) is pretty much noise immune.
    I normally use a 9 conductor shielded serial cable, just cut the ends off as needed. More flexible than CAT5.
    Jim Dawson
    Sandy, Oregon, USA
  2. #22
    I started ordering parts for Retrofit 2.0. Going with DMM AC servo kit and Centroid Acorn. Will start a build thread since I have some items I need help with... off tofind an old serial cable - thanks Jim
  3. #23
    Dec 2013
    5714
    My pleasure !
    Jim Dawson
    Sandy, Oregon, USA
  4. #24
    For questions specific to upgrading the J325 I will concentrate on another post HERE https://www.cnczone.com/forums/tree/...are-forum.html
Page 2 of 2 12
  1. Want Anilam Z-Axis Encoder BEI
    By calmissile in forum Want To Buy...Need help!
    Last Post: 09-04-2018, 05:49 AM
  2. BEI encoder replacement
    By Goslowjimbo in forum Servo Motors / Drives
    Last Post: 01-28-2017, 09:02 PM
  3. BEI Encoder trouble
    By legendboy in forum Bridgeport / Hardinge Mills
    Last Post: 09-13-2014, 03:23 AM
  4. WTB:Bei Servo encoder disc 73-250 B
    By thork in forum Want To Buy...Need help!
    Last Post: 11-19-2011, 10:47 PM
  5. Are these Litton encoders worth re-using in a retrofit?
    By Jackal66 in forum Servo Motors / Drives
    Last Post: 04-21-2011, 10:58 PM
