588,205 active members*
4,002 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Milling an 1/8" slot in 304 stainless with my G0704
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Jun 2010
    4262
    Re: Milling an 1/8" slot in 304 stainless with my G0704
    Ah well, that makes it a bit easier. 303 is a free machining chromium-nickel austenitic stainless steel supplied annealed, so it will machine more easily. But 1/2" thick is still a bit thick.
    Um - a 1/2" guard sounds a bit over the top. Really that thick?
    Anyhow, I still suggest drilling most of it, then fast shallow cuts. Don't 'rub' and make heat. Fizzissist gave some good figures.
    Cheers
    Roger
  2. #22
    the problem with drilling the bulk out is that you end up with interrupted cuts and a lot of edges that the cutter has to bust thru , those edges can easily snag a flute and snap the tool
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  3. #23
    Jun 2010
    4262
    True.
    Well, experiment.
    Cheers
    Roger
Page 2 of 2 12
  1. Cutting 0.5mm wide slot in stainless bolt head
    By greybeard in forum Material Machining Solutions
    Last Post: 06-18-2012, 05:28 PM
  2. slot cutting in stainless steel tube
    By brbeardm in forum MetalWork Discussion
    Last Post: 07-20-2011, 03:22 AM
  3. BF20's, G0704's, etc. and Y loss with 4" milling vise
    By photomankc in forum Benchtop Machines
    Last Post: 12-28-2010, 03:54 AM
  4. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  5. Machining a Slot in Stainless Steel
    By ngr1 in forum MetalWork Discussion
    Last Post: 10-04-2005, 02:20 PM
