Originally Posted by
hanermo
To lcvette..
1900$ in china..
is 400 € seafreight,
plus 1200 € customs brokerage and VAT, == 4600 €.
My frame costs about the 5000€ in tool steel, approx 2€/kg, 2000 kg.
Add 500 work hours.
But my volumetric size, for this example, is approx 20x larger, for the similar 5000€ landed cost.
For comparison purposes.
Servos, 300€/axis == 900 €.
32/4 ballscrews, 1.4 m long, x 4 = 700€.
Controller (PokeysCNC) 400€ with din rails, bits and pieces (50 connect blocks etc).
PSU 1 kW, 400€.
Pulleys, paint, stuff, 2000€.
Linear rails, about 2000€ for 35 mm hiwin, 10.4 m linear length, 10 blocks
Spindle 1500€ landed
Toolchanger 900 € landed
Servo for spindle, 2-4 kW (tbd), 1500 € landed
Approx 13-15k € for pieces.
Tooling etc. 3000€ (10-15 toolholders, 20 ER collets, facemills, endmills, inserts etc).
My machine is functionally equivalent to a medium/large industrial VMC with 1.6 m bed.
(Work area 1600 x 1200 m 400 mm. Very Large).
1/6 the power, 1/3 the rigidity, 1/3 the mass (2200 kg vs 6000 kg).
Similar (better) resolution, similar repeatability, potentially better accuracy.
Doing the verticals now, one box likely to be done today/tomorrow.
These support the bridge (bridge mill) one at each end.
The single ends are:
250x1300x20 mm, 52 kg each.
Can just lift it onto the drill press, heavy sucker.
Ends, 52 kg, x2 => 104 kg
2 ends/vertical, with 400x1300x10 mm side plates, 40 kg each, x2 => 80 kg.
+ 4 stiffeners, top, bottom, double-shelf in middle, each 250x20x400 mm, 16 kg each, => 64 kg,
+ 6 mount blocks, 50x100x250, 10 kg, => 60 kg
== 308 kg each vertical.
Vertical are separated by 1650 mm, bed width is 1600 mm.
Bridge sideplates are 2300x200x20 mm, with 2.3 m long linear rails on top, 140 kg each, x2 => 280 kg.
Bridge table (old design, welded x-frame) == 180 kg.
