Yes Don, that's the 2 step Sherline pulley modified by the vendor to fit the Taig Shaft
Nicolas
That's a beauty of a machine and I think it's convinced me to go all aluminum for my new desktop build. I'll be watching this thread with interest. Thanks!
-Mike
The control end of the machine is taking shape. The 17” monitor can swivel 45 deg on either side and can also go down 6” from its current position.
The sliding drawer for the keyboard / mouse has enough space to keep machine parameters and small tools / endmills.
Underneath the drawer the computer is installed on the right side and on the left side the controls box will be installed.
The pushbuttons station will be installed on the left side of the monitor and at about 6”- 8” from the table top.
Next week I will be starting the wiring of the motors and all the controls plus I should be getting the Sherline VS motor for the Taig spindle
Nicolas
Here is an update of my build
The pushbuttons panel layout is complete and now includes the Sherline VS unit. The panel is temporary to get the machine going and eventually I will cut it out of 1/8” thick Aluminum and engrave the description of all buttons.
The Taig spindle is connected to the Sherline motor and looks fine. All the limits are installed and wired and now working on the final wiring for the steppers and the Sherline assembly
Nicolas
Here are the last pics of my build. The table top is 1/4" thick aluminum plate and I drilled / tapped on it about 80 holes for the holding clamps. I made the 4 clamps myself out of 1/8” thick steel plate because I don’t like to have any protruding screws above the material I cut.
The machine is working and I’m fine tuning the motors / limits now.
Nicolas
Looking awesome Nicolas! You must be pretty chuffed with your efforts!
cheers,
Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
Looks great! Are you going to use some sort of a spoil board for profile and other "through" cuts?
Well Don I haven’t figured out yet what to do about the spoil board, all I know is that I need one to protect the end mills.
One option is to cover the top with a piece of 1/2" thick MDF or plywood and secure my pieces with flat head screws as needed. Or I can use 1/8” thick pressboard which I will cut to the size of the piece I will be working on and secure both with my 4 hold down clamps
Perhaps as I go along I may discover other ways, experience counts….
Nicolas
There are lots of ways to incorporate a spoil board. What works for me is to attach a piece of 3/4" mdf to the bed of my machine. (Your clamps could do that.) I then either screw the workpiece directly to the mdf or use clamps to hold the workpiece from the back.
Here's a link to show how I hold the workpiece from the back of a piece of mdf: http://www.cnczone.com/forums/diy-cn...ml#post1043015
Here's a photo to show how I screw the workpiece to the mdf:
Thank you Don for the info, very interesting
I like your idea with the keyholes on the back of the workpiece and I will keep it in mind.
BTW the carving you did on the link is amazing.
Much appreciated
Nicolas
Very nice build. Love the cable track......waiting for the videos.
Why not use a spacers for the heavier materials and a thin spoil board for the lighter stuff.
That's another good idea, thanks
Nicolas
Here are some pics of the revised Y&A axes home switches plus the negative Z axis limit. I found that I needed an accurate way to micro adjust these limits and so this new simple design does an excellent job.
I also did today my 1st trial cut on MDF. The video is on the link below and I used an 1/8” single flute end mill with 25FPM feed rate, spindle at about 70% of its full range and a depth of cut of 1/32”. The square and circle shown turned out perfect
[ame=http://www.youtube.com/watch?v=oMdUdS_k9bY]Aluminum CNC 1st Trial Cut.AVI - YouTube[/ame]
Nicolas
Love the design and clean look of the aluminum. How has the machine been performing for you since completed? Got any pics of more video to share of projects?
Nice job, really good looking machine!!
I only have this video [ame=http://www.youtube.com/watch?v=oMdUdS_k9bY]Aluminum CNC 1st Trial Cut.AVI - YouTube[/ame]
It is during the 1st trial cuts and so far I have square / level the machine and all looks very good. Have done some engraving too for testing and that looks good.
Sorry no more pics / video for now but soon. Working on my CAD program to finalize the control panel layout which I will cut in Aluminum and it will be my 1st cut in Aluminum
Nicolas
Got some time today to work on my machine. Sorry about the old videos but I delete by mistake my YouTube account and all my videos are gone. Todays video is here 4th Trial Cut - YouTube
The results of the video are shown on the attached pics and I'm very happy with the results. The cut is a square 1.5"x1.5"x1/8" thick using a 1/16" center cut carbide end mill. First I cut a helix hole to help the lead in and then I cut the square in 4 passes. The resulting cut is excellent and what you see on the two corners is the left over from the two tabs I created in the program to hold the cut off piece in place.
Todays cut is the square at the right on the picture. Feed rate used is 10" and plunge rate is 6"
Next step is to cut the control panel cover the program of which is now done.
Nicolas
