I really appreciate your cautions and advice, since I lack practical experience. I'm learning a lot about why machines are built heavy and why good parts cost so much. (I'm already in for $2400 for just a handfull of components). What I need is some rule-of-thumb, to figure out where to start for framing.Originally Posted by Cold Fusion
You make good points about the flex. Your machine made from solid square stock -- is it solid aluminum or solid steel? What dimensions? Or are you refering to your Series II? I would love to see what a commercially available machine of similar specs looks like (with similar cutting area, power, speed). Or perhaps I should say, I would love to see what a commecial machine with similar 2hp servos looks like. It may help set my expecations of what is within reach.
Ultimately, my goal is to build the strongest and fastest machine I can, without breaking the bank. I am beginning to consider building the frame from steel beams instead of aluminum framing. I had budgeted about $1000 for the frame using aluminum framing. Steel is a lot cheaper, but I worry about how to keep the frame straight, especially if it is welded.
Aside from the flex problem, I also have a spindle speed problem. Cutting at 1500 (or 750) IPM reqiures a FAST spindle, which *sigh* means more $$.
