587,719 active members*
3,921 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Oct 2005
    267
    Well I finally found the time to re-wire the power supply. I took it back to what I think is the factory original. Let me know if you see something wrong.
    Attached Thumbnails Attached Thumbnails 001-sm.jpg   002-sm.jpg   003-sm.jpg   004-sm.jpg
  2. #22
    24220
    You only appear to have the incoming power connected.
    Although it would power up as you have it, the white and black should be reversed so the black feeds the switch/breaker instead of the neutral, also connect the green wire to ground terminal.
    Al.
    Albert E.
  3. #23
    Oct 2005
    267
    Al.
    The white and the black wire switch is easy enough. The reason I don't have out going power is because the motor this thing will drive, is over in storage. I need to go get it today and try this out. I did attach the ground because this was just a short test cord. Thanks for the input. I'll let you know how things work out.
Page 2 of 2 12
  1. spindle motor and spindle control dont work
    By customcncparts in forum Milltronics
    Last Post: 10-01-2009, 08:08 PM
  2. a paper shredder motor for spindle motor??
    By .xXACEXx. in forum DIY CNC Router Table Machines
    Last Post: 06-03-2008, 03:17 AM
  3. Servo motor used as spindle motor?
    By fatal-exception in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2007, 08:55 AM
  4. more rpms for spindle motor and spindle
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-10-2007, 08:01 PM
  5. Spindle Motor
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 08-02-2006, 01:31 PM
