Do I need a plugin to get the spindle to work with my setup(usb and motion controller) ? Thanks
No.
Did the spindle work before?
I see a lot of people trhat can't get the spindle working with those machines.
Worked fine with other software
How do you enter info to get spindle to start
Did they supply you with an .xml file?
If so, it will have all the settings in it. Just load Mach3 with that profile.
There are several different ways to set up a spindle in Mach3, and you need to know exactly what hardware you're using, and how it's wired to set it up.
I'll try that. Inches was checked at setup, but dro reads mm
