Finally... working bellows ballscrew cover... real cheap
Thanks to everyone for their input... brainstorming keeps me out of the dreaded rut.
After trying everyone's ideas... including Graham's with homemade layflat... I settled on a combination of my original stocking idea with a pinch of Hu's sewn cover and simmered gently with Graham's layflat... and don't forget to add the slinky. :cheers:
Basically I obtained some black smooth Lycra fabric ( with a four way stretch ) and sewed it into 1 1/4 " tubes. This tube is smaller than the O.D. of the slinky (1 1/2 ")... but it stretches
A hem ( like on the bottom of your pant's leg ) was sewn at both ends of the tube... leaving a 1/4" gap in the hem... into which a slinky coil could be inserted.
The tube was then turned inside out... so that the seam and hems were on the inside of the tube... and the slinky was inserted into the tube.
The slinky coil nearest the opening of the lycra tube was wound into the hem... then the other end of the slinky was pulled through to the opposite end of the tube.
By first unwinding the slinky a full 360 degrees this end was now fed into the hem... so that by the time it was fully wound in... there was no tension on the slinky.
By cutting the lycra tubes... and the slinkys... to the correct sizes before assembly I ended up with six bellows style ballscrew covers.
Attaching the bellows to the machine was easy... using velcro backed with "industrial" (?) adhesive on the machine ends and velcro "split circle" washers on the bellows.
Pictures to follow... later
Try it out... total cost CAN $1 for three slinkys... CAN $10 for 1 metre of lycra ( only used 1/3 including waste and experiments )... CAN 4 hours
for sewing ( so I'm not a seamstress )... NO MORE CRAP IN MY BALLNUTS... priceless
Gary
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
