588,204 active members*
4,004 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Im Waiting 4 Weeks For A Transformer
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    779
    Those look good Jeff. Have you checked on their prices?
    I have not myself, but the customer of mine who found the site said they were less price than Plitron.
  2. #22
    Jul 2004
    148
    sounds good, thanks everyone. Matt
  3. #23
    Apr 2004
    678
    Ahem....
    So did I. I didn't twiddle the scroll button enough to see it. With the "new look" of CNCzone, I'll probably wear it out all too soon.
  4. #24
    Jul 2004
    148
    Remedy
    This seems to work pretty good. Go to this site for Hammond mfg. click-on transformers, browse through the wide variety, then click on the map to find a distributor in your area. I found one for my area which is louisiana. It was an electronics supply out of Alabama. They had the one I needed in stock and I should get it in no more than 3 days. Heres a LINK
  5. #25
    6855
    Quote Originally Posted by ESjaavik
    Ahem....
    Try a different "display mode" maybe the hybrd mode.
  6. #26
    270
    Quote Originally Posted by FLUTE HEAD
    How much was it?
    Fred Smith - IMService
    http://www.cadcamcadcam.com
  7. #27
    Jul 2004
    148
    It was 54.00. I think the toroid that i ordered from plitron was around 65.00. This one is not a toroid though.
  8. #28
    Mar 2004
    75
    Fast, Heavy Duty Transformers, almost free
    Try a microwave oven transformer.
    The primary is usually 110 volts.
    Power is 700 to 1200 watts.
    Keep the primary coil intact.
    Strip out the secondary high voltage coil.
    Choose the voltage you need.
    All the coils I have rewound have been 1 turn = 1 volt.
    Choose a secondary wire that is heavy enough for your current draw.
    Example
    You need 25 volts RMS from a 1000 watt transformer
    Output will be 40 amps.
    Sometimes a fan is good to cool the core while it is working.
    You can place taps on your secondary to vary the outputs or wind two or three coils of whatever voltage you wish.
Page 2 of 2 12
  1. Microwave transformer built power supply
    By TinkerDJ in forum CNC Machine Related Electronics
    Last Post: 04-30-2021, 02:57 PM
  2. How to wire a toroidal transformer..need advice
    By bgolash in forum CNC Machine Related Electronics
    Last Post: 11-13-2007, 03:22 AM
  3. Replies: 3
    Last Post: 05-27-2005, 01:44 PM
  4. 3 phase transformer on single phase?
    By jevs in forum CNC Machine Related Electronics
    Last Post: 03-19-2005, 06:25 PM
  5. Connecting power transformer to 3 phase
    By keithorr in forum CNC Machine Related Electronics
    Last Post: 12-17-2004, 08:52 AM
