588,574 active members*
12,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > unrecoverable memory error
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Nov 2019
    6
    Yep. We did all that this evening. Like I said - a dry run
  2. #22
    May 2019
    29
    Re: unrecoverable memory error
    Hi All,
    I ran into a unrecoverable memory error at 007B today, but next to that I suspect some more memory issues.
    Before the memory error occurred already, when I looked at the tool table, the DT command shows very weird values (see attached picture)
    Also the parameters and the BL values were lost which I have to re-enter every time the machine starts (looks like at least a broken backup battery)
    Would a zero memory procedure be sufficient here or would these issues mean a new CPU board?
    Any help is very much appreciated
  3. #23
    Jun 2006
    241
    I got some really weird stuff on the screen after I pulled the memory board out to replace the battery. It took a few restarts before I could even get it to start up so I could zero the memory.
    I would definitely try the zero memory procedure. I would also recommend replacing the memory board battery if you don't know how old it is.
    This video shows how to replace the battery.
    https://youtu.be/OuYS4KLvQyk?si=DHiv9W20RDRymONw
    This is the battery on eBay https://www.ebay.com/itm/184450539247
  4. #24
    May 2019
    29
    Hi All,
    Thank you so much for the advice.
    I ran the zero memory procedure and everything is back to normal again.
    The battery most likely will need to be replaced soon, so that's high on my todo list.
    Best regards & thanks again
Page 2 of 2 12
  1. Unrecoverable memory error
    By voytek1 in forum Fadal
    Last Post: 05-14-2021, 12:26 AM
  2. unrecoverable memory error
    By Michael82 in forum Fadal
    Last Post: 10-14-2009, 07:46 PM
  3. Out of memory error
    By zachf in forum BobCad-Cam
    Last Post: 07-31-2008, 02:22 PM
  4. EMC memory error
    By tomekbrzozowski in forum LinuxCNC (formerly EMC2)
    Last Post: 07-03-2006, 09:04 PM
