587,999 active members*
2,603 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 67db at 5100 rpm? 2x better surface finish?
Page 2 of 3 123
Results 21 to 40 of 47
  1. #21
    Sep 2012
    1543
    Re: 67db at 5100 rpm? 2x better surface finish?
    I don't have a fancy DB mic, and the phone used to measure was an "iphone" which I don't even like in my house.
    No Matter, numbers aside. the noise from the day I bought my Tormach, to today is INCREDIBLY different and pleasant now. Maybe I started with a Lemon?
  2. #22
    Jun 2014
    1780
    My compressor is another story, makes one appreciate the quietness of the Tormach.
    5 hp compressor at 6 feet is 94 db, now thats noisy!!
    mike sr
  3. #23
    Jul 2004
    1424
    Quote Originally Posted by BAMCNC.COM View Post
    If you had a new machine this mod would give you the lower sound and vibration hands down. They can't "apply" the bearing change mod, however they can sell an electric fan kit. No matter what, with no fan, you will have less vibration and less sound.
    I seem to remember a thread talking about how somewhere along the line, Tormach modified the fan in the motor to better balance it. So maybe your mod doesn't necessarily apply to new machines? I will have to pull off the fan cover and take a look at mine.
    My recollection is that the original fan had a bolt as a set-screw holding it to the shaft, and the bolt head did bad things to the balance.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  4. #24
    Feb 2006
    7063
    These machines always need some time to "break in". My Torus Pro was also noisy when I first got it, and had some vibration at some speeds. After just a few days, it quieted down, and it's now nice and smooth and quiet. In the case of the Torus Pro, most of the initial noise and vibration seemed to be the HUGE timing belt in the head. But, even a V-belt will quiet down after some use, as it wears to better fit the pulleys, and becomes more flexible. It's now quieter at 6000 RPM than it is at lower speeds. The noise also varies a lot based on the VFD being used. Being an alpha tester, I've had quite a few different VFDs on my machine, and each has its own unique sound. Never a problem with fan noise, since the machine comes with a nice, quiet electric fan.
    Regards,
    Ray L.
  5. #25
    Nov 2007
    2151
    Quote Originally Posted by TurboStep View Post
    Improve accuracy and finish ???
    NO ???????
    And I will buy your mesa card, BAM. pm me price!
  6. #26
    15362
    Maybe you have bad spindle MOTOR bearings? Take a look at how Tormach China balances their rotors... https://instagram.com/p/6YHUOkFUPC
    The Chinese must of copied how most American motor manufactures balance their motors, they use the same method, the photos are of a major US manufacturer, most low speed motors are balanced this way, this could've been a little neater in the way your was done, so those bashing the way Chinese rotors are made, have not, ever seen a US made one, I have rebuilt hundreds & most balance them this way
    Mactec54
  7. #27
    Jul 2004
    1424
    Quote Originally Posted by SCzEngrgGroup View Post
    Do you have a picture of that? I would be interested to see how they implemented it. If I had a 3D printer, I would print a cowling to mount a muffin fan in to replace the existing fan and cowling. I have a very nice 120V muffin fan that is about the perfect size.
    Tim
  8. #28
    Feb 2006
    7063
    Quote Originally Posted by tmarks11 View Post
    It is a large (~5" diameter?) 220V muffin fan, mounted above the air intake on the top of the motor, with a very simple spot-welded cylindrical sheet-metal housing that fits snugly over the end of the motor.
    Regards,
    Ray L.
  9. #29
    Sep 2012
    1543
    Quote Originally Posted by mountaindew View Post
    NO ???????
    $60? I think I had to modify the bracket that holds it to fit the PC it went into.
    I've only rebuilt around 1000 motors, but they were GE motors and I don't know the origin. (From GE 1.5 MW Wind Turbines) They had holes drill in them if I remember right.
    Quote Originally Posted by popspipes View Post
    Put a Diesel Fuel filter on your intake, you will notice less noise, and less water in your tank. I have a video on it.
    I have the better Tormach "self balancing fan" and it looks like a Chinese kid made it with a pair of scissors. It's posted on CNCZone in the "Finish" thread I believe.
    It wont' let me quote more than this.. so RAY, You are just backing up what I have said. The 67DB is the LOUDEST this will be, it gets quieter everyday.
  10. #30
    Sep 2012
    1543
    Just installed the fenner belt, when new it was 69db, and sounded terrible. Took it off and put back on my old Mitsubishi belt and now we are at 64-65db. Things are breaking in, I LOVE it!!!
  11. #31
    how have people that have done the electric fan mod wire the fan? Do you wire it into the panel some how, or just simply give it it's own power and switch?
  12. #32
    Jun 2014
    1780
    Quote Originally Posted by Concepts_Design View Post
    In my case the spindle nut (PDB) and motor fan balance was the key issues in reducing noise, this also greatly improves finish.
    The Fenner belt was noisy when it was new.
    I can talk on the phone now while the machine runs at max rpm, couldnt do that when the machine was new.
    mike sr
  13. #33
    Jan 2007
    311
    Anyone ?? Is there a switched supply that maybe comes on with the spindle power (not spindle turning) ??
    M
  14. #34
    Jul 2004
    1424
    Quote Originally Posted by Mooser View Post
    On the VFD, put a 24VDC relay from connections T1 and B3. B3 will have 24vDC on it whenever the spindle is moving, so the relay will be powered as long as the spindle is turning. You can use that relay to turn on and off the spindle fan (don't try to power a 24V fan directly off of the B3 terminal... bad things will happen).
    These are the same terminals that the ATC uses as an interlock to prevent tool change to a moving spindle. And the same terminals that some people have used to make a safety interlock to prevent dropping a tool with the PDB while the spindle is turning.
    http://www.cnczone.com/forums/tormac...ml#post1459808
    Tim
  15. #35
    Jun 2014
    1780
    PDB pushbutton safety
    works exactly as stated and has here for a year or so. I put a 24 volt relay in series with the push button tool release, I dont have the tool changer.
    This has saved many tools and aggravation here.
    mike sr
  16. #36
    Jan 2007
    311
    I was originally thinking of something that would keep the fan running even without the spindle so that it can be pulling heat even during tool changes etc. (I have power toolbar but no tool changer) but this should be good anyway. now to find a way of getting wires back there (every once in a while I regret putting the machine tight into a corner....)
    M
  17. #37
    Jul 2004
    1424
    Get a 240V muffin fan and wire it directly (with an inline fuse) off the C2 contactor output. Any time the VFD is powered up, the fan will turn.
    Tim
  18. #38
    Jan 2007
    311
    Thanks, that's more along the lines of what I was thinking. Probably overkill but can't hurt
    M
  19. #39
    Jun 2006
    3063
    Sorry to resurrect a somewhat old thread, but Phil asked if anyone had collected noise data and I just did that with the Sound Meter app (by ABC Apps - https://play.google.com/store/apps/d...ebasic.decibel) both with and without the fan. The results were:
    With Without
    Spindle, Fan, Fan,
    rpm dB dB
    2500 58 57
    3000 62 60
    3500 66 62
    4000 70 59
    4500 74 63
    5000 75 64
    This is on S/N 119 built in 2008 or so and is a Series I that has been electrically upgraded to a Series III running PathPilot. The fan was filthy and coated with oil and sawdust from a bout of wood milling a year ago or so. Before the test, I cleaned the fan and deburred the edges of the blades, many of which had sharp molding flash. I wish that I had measured the sound levels before cleaning and deburring the fan because it sounded quieter after that bit of maintenance. The readings are uncalibrated so probably only of comparative value withing this data set.
    The motor was quite quiet without the belt and fan, which probably makes sense. I'm inclined to install a 220 VAC fan just because it is inexpensive and pretty easy to do but am not sure if I want to go to the trouble of balancing the pulleys or drawbar nut until I see how the fan affects things. As it is now, I'm reluctant to mill at higher than 3500 or 4000 rpm spindle speed because the noise doesn't sound good, but that was with a dirty fan.
  20. #40
    Jun 2006
    2512
    Quote Originally Posted by MichaelHenry View Post
    Sorry to resurrect a somewhat old thread, but Phil asked if anyone had collected noise data.
    Thanks for that Michael, It will be interesting to see the result if/when you fit the electric fan.
    I use ear defenders most of the time, they have the added advantage that any crashes are not nearly so bad.
    I did a subjective noise test of mine at the time of the previous post and it was clear that the motor fan was a major contributor. It was at this time that I figured ear defenders were the quickest fix.
    Phil
Page 2 of 3 123
  1. Surface Finish
    By pgf545 in forum PTC Pro/Manufacture
    Last Post: 01-24-2012, 04:03 PM
  2. bad surface finish
    By tunitime in forum MetalWork Discussion
    Last Post: 10-25-2009, 05:35 PM
  3. 64 RMS Surface Finish?
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 01-13-2009, 11:19 AM
  4. Surface finish
    By chakaloso in forum Uncategorised MetalWorking Machines
    Last Post: 06-13-2007, 02:54 AM
  5. surface finish
    By fadalman in forum BobCad-Cam
    Last Post: 03-03-2007, 08:30 AM
