I picked this up a few days ago , and haven't had time to use it yet :banana:
Hello again,
Not trying to hijack your thread and turn it into a thread about my build, but seeing your pic of the IVTAAQ rail mounted in post #1 has caused me to redesign my whole project.
The Pacific Bearing website does not show the IVTAAQ rail with an alignment tab in it's drawings. Also, if you go to the cad drawings section it gives the option to add a tab (or two tabs) on all the other rails of that family, but not on the IVTAAQ.
Was there anything special you needed to do to get that rail made up with an alignment tab so it would fit with the 40 series 8020, or did you just specify the alignment tab option in the ordering code and presto?
NIC
No . it fits perfect
hello,
what type of stepper motor you used (how many oz-in...).Thanks
I m using 600 oz. motors , dragon cut kit from c andcnc
NIC 77 stated:
I'm about to start a 4 x 8 cutting area shopdroids build myself. It's going to be for Routing and Plasma. The one weakness, in my opinion, of using the shopdroids design for larger builds is the lack of stiffness. An aluminum T-slot extrusion 2 inches by 2 inches could have alot of flex over a 4 foot span.
NIC 77, I am builting a Shop Droid for routing that is 83-inches by 53-inches. I use 3030 t-slot from 8020. http://www.cnczone.com/forums/cnc_wo..._sized%5D.html
I did moment of inertia calculations on the 83-inch length and with the use of a leg in the middle got the deflection to 3/10,000-inch assuming a load of 500-pounds evenly distributed, and support only at both ends and in the middle, and this did not take into consideration any of the cross beams which reduces deflection even more.
Though I do not have the statistics for the material you are going to use, my suggestion to reduce deflection to next to nothing would be to put a leg in the middle of both the sides. The deflection over two-feet will be almost nil. The deflection over the 8-foot side will be almost nil as well.
Zool,
I've replied to your post in your build thread. I don't want to hijack this thread any more than I have with my long winded comments, and I've got alot to say about your post.
O k , boy what an experience this has been . Newbies heres some info , after the table is built thats the easy part [ more on that later ]. But today damn it ,I roboticaly designed and cut my first part !!!!:cheers:
Heres a pic of third cut on my slat design
B y part three the outer part just feel off , so cool ! Stiil gotta lot to learn .
I had never seen sheet cam or a design program or mach till a few weeks a go . I kept telling my self , something my 84 year old former brick mason father in law told me once . I ask him how he learned the trade , he said I saw some brick masons working one day and I just told my self that if they can do it , so can I !
O h what a roller coaster week it has been , My primary business is sucking bad right now , due largely to the idiots running the country . So I tried to stay up beat , but it was very hard . I got stuck on numerous little details trying to get the machine to cut , so now at this very monent , I will open ice cold beer number three !:banana:
Slat jig I made
Slats all installed , Homing switches mounted on hard stops I got the d t h c
running today .
320 ipm ,direct drive ,this is how it fell out of the sheet untouched .
I thought this was pretty good for a complete rookie , who never saw sheetcam , mach , candcnc stuff until a few months ago .
Belt reductions are currently being built
Still tinkering with my machine . I scored a water tank from Culligan water ,dumpster diving . Its a wellmate , heavy fiberglass 120 gal . about 600.00 new , I got for free . They didn't know what was wrong with it , turns out a busted pvc fitting on the outside of it :cheers:.
Added a swivel monitor stand , e trac on y so far . shelves for my cpu .
Looks great! Simple and obviously very effective.
JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
Joes 4x4 R&P in progress
I am also very new to this...I have a little corel experince making the dxf files etc...but none with the sheetcam...when you put a dxf file in the sheet cam does it automacticly change to the code so the machine nows where to start? ordering my parts tonight thx for any advice or info
Hammerdown,
No it does not do that . You must set up your table dimensions in sheetcam first . Then you import your dxf file . As its importing it ,you have a chance to scale it [ set the cut size ] . It wiil then show up on your table . Click the + icon [ nesting ] to drag it arround where you want the part on your table . Unclick the nesting icon . Now you must set up a cut tool [plasma ] use your plasma cutting machines suggestions for the settings , based on material thickness . Click ok and that part of tool setup is done . Now you must set up an operation , this is where the new cutting tool will know how to cut the part . The layer box is very important , click on it to asign a layer to your part to cut . After the operation is set , save as , then click the post process button . You now have created g code . This file must be transfered to your cutting machines computer .
I highly recommend anyone learning , join the Yahoo Groups for , Sheetcam , Mach , And CandCnc .
cool thank you for the help
