588,665 active members*
7,501 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 problem, steppers not moving
Page 2 of 2 12
Results 21 to 37 of 37
  1. #21
    Aug 2006
    673
    if I don't have the estop emulated, it's constantly in estop mode. yeah, I've tried it pretty much every combination you can think of.
  2. #22
    Feb 2007
    4553
    Smile
    Please uncheck the Estop active low and also Estop emulated.
  3. #23
    Aug 2006
    673
    when i have them both unchecked it keeps triggering an outside estop.
    I check for continuity between pins 10 and 12 (and also pin 10 and my PS V-) so the G540 should think there is an estop switch installed and not activated. the only way to get the estop off was to check the emulated box.
  4. #24
    Feb 2007
    4553
    Smile
    ok try setting port to 0 for Estop that will should bypass Estop
  5. #25
    Feb 2007
    4553
    Smile
    Do you have a instant messenger?
  6. #26
    Aug 2006
    673
    I don't at the current second. i'd have to re-download it. give me a bit....
  7. #27
    Feb 2007
    4553
    AOL Messenger: jalessi
    Yahoo Messenger: alchemist135
  8. #28
    Jul 2006
    887
    Have you checked to see that in the bios your printer port is set to EPP? This was an issue for me.
  9. #29
    Feb 2007
    4553
    Smile
    Your LPT port settings in your bios are wrong or the cable is not correct, that is why the Estop condition wont go away!
  10. #30
    Aug 2006
    673
    jalessi, funny you should say that. I called up Gecko today and spoke with one of the engineers. we have it narrowed down to either a faulty cable, or a bad parallel port on my PC (which i doubt, since it was working fine just a few days ago).
    Fixittt, yup I switched that today as well without any luck.
  11. #31
    Jul 2006
    887
    what cable are you using to run the gecko? I know its not the one that was running your xylotex unless you put a gender changer on it. can you check the cable to make sure that it is a straight thru cable?
  12. #32
    Feb 2007
    4553
    Smile
    Cliff,
    You can thank Fixittt for the solution, we where talking about your problem and he was the one that figured it out.
    Jeff...
  13. #33
    Aug 2006
    673
    Quote Originally Posted by Fixittt View Post
    just a regular m/m 25pin par data cable. so if it's a straight thru I'm assuming I can check continuity between pin 1 and pin 1 on either side of the cable, pin 2 and pin 2, ect..?
    and thanks Fixittt! hopefully this is my problem.
  14. #34
    Jul 2006
    887
    i am going to assume that you are running the xylotex 269`s on the g540? it will work as I have a machine with the same setup. I have smaller resistors then you have though. And I am using the 24v xylotex PSU and the machine still flys. I would suggest that you call around and find a gender changer for the end of your cable that was working with the xylotex setup.
  15. #35
    Aug 2006
    673
    ok, i'll have to give that a try.
  16. #36
    Jul 2006
    887
    Im willing to place a very large $$$$ bet that its your cable that is the problem. we know that the xylotex cable works, just needs the end changed to match up to the gecko drive. There is a very likley hood that the cable you have maybe a data transfer cable. Just looking at the ends will not do it. it has to be a straight or PASS thru cable.
  17. #37
    Aug 2006
    673
    You sir, are correct! I got a male/male adapter, and plugged in my old cable I used with the Xylotex, and she works, oh so nice, now. Thank you guys SO much.
    special thanks to jalessi, the slave driver, who had me reinstalling mach3 at nearly 1 in the morning trying to troubleshoot over AIM. what a stand-up guy. People like you is what makes this forum a invaluable resource for everyone.
    also special thanks to Fixittt, who lived up to his name, and help me get me rolling again!
Page 2 of 2 12
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. G540 fault problem
    By jemmyell in forum Gecko Drives
    Last Post: 10-21-2008, 11:50 PM
  3. Problem with manual moving in emc2
    By ad_Wolf in forum LinuxCNC (formerly EMC2)
    Last Post: 06-30-2008, 11:05 PM
  4. Discussion of moving table vs moving gantry
    By rkremser in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 10:59 PM
  5. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
