588,127 active members*
4,957 visitors online*
Page 2 of 2 12
Results 21 to 39 of 39
  1. #21
    Jan 2007
    161
    Thumbs up I still need help trouble shooting this issue.
    Well I built the 9 pin to 25pin cable and have it plugged into the correct port on the computer. I am getting closer. Now I get P/S alarm87 or 85 depending on how I set the stop bits, data bits and parity. My book doesn't say how to correct the alarms. I have been playing with it for more than an hour and can't figure it out.
    I still need help trouble shooting this issue. I have Cimco edit for transmitting. Is there something else that can work better?
    Thanks.
    _____________
    teamjnz
  2. #22
    24220
    9 out of 10 this is the hardware handshake, as long as you are on the right port and there is nothing wrong with the port, can you output from machine to PC?
    Did you make up a 3 wire cable or the full handshake null modem version?
    Al.
    Albert E.
  3. #23
    Jan 2007
    161
    Hi Al,
    This is the diagram that I referenced to.
    http://www.kfasllc.com/rs232_cable.htm
    It looks like the same that you gave me. The visual is good for me. I have know idea if this is a null full handshake or 3 wire.
    As for outputting from the machine I don't believe that I can since there is only an INPUT button. There is no OUTPUT button. It is a system 3M Fanuc controller.
    Thanks again.
    _____________
    teamjnz
  4. #24
    24220
    Did you set the transmit S/W for software handshake?
    Al.
    Albert E.
  5. #25
    Jan 2007
    161
    Yes.. I have tried software, hardware and the hardware & software combo flow control. I have tried different stop bit, data bit and parity configurations. Some bring alarms and some configurations don't put the machine into alarm. It just sits there blinking LSK.
    There are Xon and Xoff characters. That I haven't played with.
    Example:
    \17 Xon
    \19 Xoff
    There is also buttons to turn on and off. They turn on and off automatically with different flow control options.
    Example:
    Enable DTS
    Enable RTS
    _____________
    teamjnz
  6. #26
    Jan 2007
    161
    FIGURED IT OUT!!
    I finally got it figured out. :banana::banana::banana:
    I wasn't typing in the program number and then pressing input. I was just pressing input. It has been a long time since I have used and older control. I have been using floppies on Haas or CF cards on the Fanucs.
    Al I really appreciate your time in helping.
    _____________
    teamjnz
  7. #27
    Dec 2008
    27
    Smile Just Built A Cable My Self Today 3/4/09
    I just built a cable today it works perfect. I have a 92 Mycenter1 with Fanuc OMC – 6 the pinots below should work on yours as well.
    Here is what I used
    25 Pin DSub 9 Pin DSub
    Pin 7-------------Pin 5
    Pin 2-------------Pin 2
    Pin 3-------------Pin 3
    Jump 4 and 5 Jump 7 and 8
    Jump 6,8,20 Jump 6,1,4
    Stop Bits 7 and 2
    Parity Even
    Dont use handshake.
  8. #28
    Sep 2007
    371
    Hi teamjnz,
    We have a similar machine than yours, Kitamura, Mycenter-1, with Fanuc 3M controller, recently we losted all memory contents, is there a chance that you could give us a backup of your PC and PMC parameters???
    I really hope so, and I thank you in advance for your help.
    Greg.
  9. #29
    Dec 2008
    27
    Sure I can get you a copy. It will be either Monday or Tuesday. Just want to fore warn that my Z axis multiplier is set different from stock. Someone changed the encoder and put one for 10mm pitch screw, it should be a 6mm off the top of my head, I believe. If you still want the files let know.
  10. #30
    Sep 2007
    371
    No problem with that, we will be careful with that parameters. We'll need the NC and PC param. please. What we need mainly are the PC parameters, they are on the diagnostics screens. I will wait for your reply monday or tuesday.
    Thank you very much.
    Greg.
  11. #31
    Jan 2007
    161
    Quote Originally Posted by GPena View Post
    Hi teamjnz,
    Greg.
    What year is your My1. My machine is a 1984.
    _____________
    teamjnz
  12. #32
    Dec 2008
    27
    Hi Getting ready to start up the machine what's your email? Mine is [email protected]
  13. #33
    Sep 2007
    371
    Mine is 1983...
  14. #34
    Dec 2008
    27
    Hi got the parameters, 1983... isn't a complete email address nor did I receive a private email to send the file.
  15. #35
    Jan 2007
    161
    Mine is 1983...
    I will take pictures of CRT screens with my parameter numbers and upload them. They should work on a 1983 machine.
    Until then...
    _____________
    teamjnz
  16. #36
    Sep 2007
    371
    I will wait, thank you...
    Greg.
  17. #37
    Jan 2007
    161
    Greg.
    opps... Sorry Greg I totally forgot. I have been really busy.
    _____________
    teamjnz
  18. #38
    Sep 2007
    371
    No problem, I will wait for that as soon as you can.
    Greg.
  19. #39
    Jan 2007
    161
    Greg.
    Hi Greg,
    PM me with your email and I will give you a link to the images.
    _____________
    teamjnz
Page 2 of 2 12
  1. What software is necessary for RS232 Communication?
    By 61SedanMan in forum Haas Mills
    Last Post: 08-31-2017, 11:22 AM
  2. USB to RS232 NO Communication?
    By frz400 in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 11:16 PM
  3. RS232 communication on Fanuc 21i-TB control
    By dittrichw in forum Fanuc
    Last Post: 06-09-2008, 12:02 PM
  4. RS232 communication software
    By gar in forum Haas Mills
    Last Post: 08-14-2007, 02:56 AM
  5. Help! RS232 Communication to Fanuc 3T Control
    By m1_machine in forum Fanuc
    Last Post: 10-30-2006, 09:08 PM
