588,665 active members*
7,667 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > New machine: small, sturdy, high performance. Input needed!
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Feb 2007
    473
    Re: New machine: small, sturdy, high performance. Input needed!
    Just stumbled across this thread again, thought you guys might like an update!
    I ended up getting a Vertical Machining Center, after a lot of searching I found a beat up Fadal VMC10 for a very reasonable price, cost me significantly less than a Tormach! I then spent about 2 months doing a lot of remedial maintenance on it to help ensure it wouldn't develop any problems.
    I've only recently started actually using it to make parts because I had to save up cash for a compressor and tooling and so on. I had my first crack at the part I described at the start of this thread just the other day:
    That toolpath is not anywhere near optimized, just wanted to see whether I was getting close! The actual part itself came out almost perfect, the largest flaw is the missed strip along the top of the scales due to the tool diameter being incorrect. With that changed and a few other tweaks I should be getting parts that are bang-on!
    -Aaron
    Gough Custom - http://goughcustom.com/
  2. #22
    Jun 2012
    817
    Cool vid. I bet an ATC would come in handy.
  3. #23
    Feb 2007
    473
    Quote Originally Posted by Devastator View Post
    Thanks mate!
    The machine does actually have a 16 station ATC, it's just a bit slow which might have given you the impression I was hand-loading tools...
Page 2 of 2 12
  1. High Performance Cutting
    By kalmah in forum MetalWork Discussion
    Last Post: 06-01-2006, 02:36 PM
  2. High Performance Machining or HSM
    By Scott_bob in forum Polls
    Last Post: 04-27-2006, 08:34 PM
