587,770 active members*
3,244 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > I Need Suggestions for a Vacuum Table
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Re: I Need Suggestions for a Vacuum Table
    Nothing's easier than setting a part on the spoilboard, snd turning on the vacuum switch.
    If your buying a Shop Sabre, buy it with a vacuum table.
    No single hold down method will work perfectly for all parts, so you may need to do somethi g different when the job requires it.
  2. #22
    Nov 2010
    177
    Yeah ... I tried to use The Force, but I am beginning to believe that really doesn't work.
  3. #23
    May 2018
    88
    The spoilboard needs an air tight surface underneath it, to hold the vacuum.
    You also need to remove about 0.01" from each side of the MDF, to allow more flow through it Yes, as you expose more of the spoilboard, you get vacuum leaks, and holding force decreases.This is part of why you need very high flow rates.
    ^^^^This, and seal the edge of the spoilboard with paint or just run it through your edgebander if you have one.
Page 2 of 2 12
  1. Vacuum pump suggestions
    By Keskin in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-21-2019, 04:22 PM
  2. Vacuum table help. Custom table for small acrylic parts.
    By czwalga in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-09-2014, 03:06 PM
  3. Vacuum table and vacuum pump
    By garagefela in forum DIY CNC Router Table Machines
    Last Post: 01-25-2012, 05:30 PM
  4. Suggestions for my Vacuum system please
    By Realmseeker in forum DIY CNC Router Table Machines
    Last Post: 06-27-2010, 06:34 AM
  5. Newbie Vacuum Forming Table wanted Suggestions
    By darticus in forum Vacuum forming, Thermoforming etc
    Last Post: 07-06-2008, 04:04 PM
