Photos of diy lathe #1:
Patterns:
Headstock, countershaft, lathe bed:
The bottom of the headstock:
I decided to put some old-school curves in the feet:
I filled the lathe bed's square steel tube with Commercial Grade Quikrete Fast-set Non-shrink Grout with a piece of rebar going down the middle.
I also used Bondo where the castings shrunk from the sand a little. I was going to paint it all green like the countershaft.
As I said before, I am going to move on to diy lathe attempt #2. What I plan to try with this lathe bed is to make it into a scraping reference plate. I will attach handles where I screwed in the feet. I have heard the advice that steel is not a good substance for making scraping references, because it twists as you take material off. Granite makes a great reference. So, I figure maybe by adding the non-shrinking grout, some of solid properties of stone will be gained. I figure it is worth a try. For almost no money, and some elbow grease, I could have a 36" flat reference to use in scraping mill and lathe ways. It has already been ground, so it is close to flat already.
Comments very welcome,
Dave
