587,096 active members*
6,940 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Bypass/Disable ATC on a Okuma MX 45 VAE/OSP 700M
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Apr 2009
    1262
    Re: Bypass/Disable ATC on a Okuma MX 45 VAE/OSP 700M
    Quote Originally Posted by TampaCNC View Post
    How do I achieve turning off the spec? :stickpoke
    You must PATCH the spec code file.
    You may need to unprotect the file to accomplish this.
    On non windows machines:
    Boot with SW switch ON
    DIR MD0:,PN:;P
    PROT FILENAME.CNC;U
    PATCH FILENAME.CNC,PN: (displays file on panel)
    S1 (sector 1)
    find the code to change...this long number is your spec code if you change your sheet sideways and convert the binary (4 bits + 4 bits) to hex (2 characters). ex: 0010 0011 = 23
    QUIT once finished changing.
    reboot the machine
    This will change the spec code for test purposes. It will display TEST SOFTWARE when powering up.
    This is intended for testing and of course software updates from Okuma are needed for a permanent change.
    If you desire to reprotect the file, follow the same procedure but remaove the ;U from the PROT command.
    Merry Christmas!
    Experience is what you get just after you needed it.
  2. #22
    Aug 2019
    29
    H?
    i can do anything about software contact me
  3. #23
    Mar 2015
    21
    We are scrapping the machine.
    R.I.P. Okuma
  4. #24
    Jan 2013
    474
    R.I.P. Okuma
    Bye.... Sorry.
    The only thing I could think of is to name each tool as a special tool needing to be hand loaded. The machine will then stop, release the door to allow manual toolchanging. Close and lock the door and press cycle start to continue.
  5. #25
    Jun 2015
    4156
    hy if you are scraping it mostly for the very issue discussed in this thread, pls make sure that you try all advices before you proceed
    if you wish, i can guide you through / kindly
Page 2 of 2 12
  1. Replies: 2
    Last Post: 09-23-2019, 01:37 AM
  2. OKUMA OSP 700M Error code 5427
    By joacom in forum Okuma
    Last Post: 06-25-2019, 07:20 AM
  3. Okuma OSP 700M/7000M RS-232 parameters
    By sld4121 in forum Uncategorised MetalWorking Machines
    Last Post: 05-01-2013, 06:33 PM
  4. okuma osp 700m
    By bennyboy78 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-14-2011, 02:07 PM
  5. Okuma Osp-700m Dnc Parameters !!!
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-16-2007, 04:13 PM
