There are several settings that effect the DTHC response curve. See the section in the DTHC manual on each of the settings. Find the section on THC RATE (a MACH setting on the SETTINGS TAB. The Z while in THC mode does not use an acceleration/deacceleration curve. To prevent stalling the motor you have to lower the VELOCITY. The THC Rate defines the percentage of the Z velocity (set in the motor tuning) that it uses WHILE unrer THC control.
One of the steps we advise is to get the system setup and running good with conventional tips (40A or 60A) at the conventional gaps (.063). If you get good results there THEN advance to doing Fine Cuts. Be aware that Fine Cut charts call for different parameters (arc gap, voltage presets, feedrates, etc.
Another setting that determines the response curve is the SPAN setting in the Cut Profile. You will find that different nozzle sizes on different material may need some fine tuning of the SPAN and maybe even the Fault trip points and/or the TIP Saver %. The concept of having the CUT PROFILE and being able to have stored settings is to be able to make some specific changes and have the DTHC use them for a given type of material.
The THC Rate setting in MACH is of course Global for all cutting with THC. The final mechanics have a lot to do with what those settings need to be. Cutting with Fine Cut consummables is the most challenging and you have to adhere to the suggested arc gap, current and feedrates for the given material. If the DTHC is moving a lot it means the voltage feedback is changing rapidly. The unit will respond and correct very rapidly and the SPAN setting determines how tightly it tries to hold the voltage to the preset. Example: the default 4/4 setting = 1Volt so the torch will adjust to try and hold the voltage to + or - one volt. If you are cutting too slow the voltage may be moving around a lot.
What I am trying to convey is that if you don't have the other factors set right (feedrate, clean-dry air, arc gap, cut current, air pressure, good workclamp connection, etc) then you can see voltage fluctuations that can cause problems holding a constant height/ Changing the THC rate down can dampen the movement but that also impacts the response time and may result in bad cuts.
Do not make wholesale changes to the settings and never more than one at a time.
First do some test cuts with THC off in MACH and observe what kind of feedback you are getting. The TORCH VOLTS on the screen will give you a real time read out of what it is seeing.
One of the reasons we introduced the new DCP-01 Digital Current Probe is with it you can actually see another of the important factors of a good cut: The actual cutting current at the torch. That value is supposed to remain constant and be close to the dial setting you have on the Plasma BUT if it's not you have no way to know. If it varies during a cut then the voltage will vary and the DTHC will see that as a varying arc gap distance and try to adjust.
TOM caudle
www.CandCNC.com
