Re: G code translator for Galil
If Mach issued step/dir to Galil there would be no point going Galil.
Galil receives look ahead command over the bus, whether PC slot or USB similar to the way that Camsoft issues commands.
I have even used the old Galil legacy type to do this using the Terminal program, but unfortunately Mach is not compatible with Galil Legacy versions.
Al.
Albert E.
