588,616 active members*
5,978 visitors online*
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Feb 2009
    2143
    Re: Buying a used Mikini
    Making some headway, here is the current version of the schematic:
    I have debugged it and all seems to be working in manual mode (I don't have the VFD yet, but the F/W and Run/Stop work, as well as a readout I put in for spindle speed, Z-bit, and an 84 ppm signal for the Mikini). Only hiccup so far is M3 and M4 don't seem to switch to RUN mode when in Mach control. May be a function of the VFD not being installed, though, so I am not too worried yet. I actually did all the programming of the Arduino myself after a bit of a training session with my work buddy. It's been fun! I added a small OLED screen to read out the modes and the spindle command and and actual speed so I have a bit of diagnostics feedback.
    The PWM signals from the Mikini and Mach3 are so slow I am able to convert the PWM to spindle command speed directly in the Arduino instead of using a PWM to analog 0-10 v box. The box didn't work well since the signal was so slow. I think the Mikini is 8 hz, and Mach3 is set to 25 hz. The box wants 100 hz but would prefer 1 khz! It was a bugger to figure out how to parse the PWM signal in C, but I figured it out!!!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  2. #22
    Dec 2005
    49
    Interesting approach, I had thought about doing something like that, but then I just went ahead and bought a Centroid Acorn and DMM servos. Very easy conversion, except for having to cut out the casting to get to the Z motor. I had to buy a bigger angle grinder to get thru the thick casting. Still need to put the new Z servo in...
    I did replace the Mikini BLDC control after I accidentally shorted it out.
    I bought a new BLDC drive, but I still have the Mikini motor and it works fine.
    The second Mikini I bought was converted to parts from CNC4PC, but I'll go ahead and switch to Centroid so it matches my existing Mikini and Hardinge Accuslide (also DMM servos)
    I tried Mach and found it to be very difficult to use. The Centroid software is great and actually makes sense to me. It's more like the Haas and Fanuc controls I ran before I retired. BTW I was a prototype machinist for 42 years and design engineer for 20.
    Tinmuk
    Any problem can be solved by the proper application of heat!
Page 2 of 2 12
  1. Used the Mikini to route a PCB...
    By mcphill in forum Mikinimech
    Last Post: 04-12-2012, 01:54 AM
  2. My new Mikini 1610L (at least to me)
    By slowtwitch in forum Mikinimech
    Last Post: 06-24-2011, 12:32 AM
  3. Anyone have the Mikini 4th axis?
    Last Post: 02-06-2011, 03:03 AM
  4. CAD for the Mikini
    By choppero in forum Mikinimech
    Last Post: 01-11-2011, 08:16 PM
  5. Mikini 1610L
    By HLF Ordnance in forum Uncategorised MetalWorking Machines
    Last Post: 11-14-2009, 03:19 PM
