588,124 active members*
4,861 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Nov 2006
    134
    Re: EndMill Holder pulled out of TTS
    OK, once again my poor choice of words has derailed my point. You can substitute "vibration" for instances of "chatter" in my description of the pullout problem areas, because that is more what I was attempting to imply than conditions specific to the traditional machinist's definition of tool chatter. Of course we should not be operating under chatter conditions under normal circumstances. Chatter is a specific condition that is a problem by definition, yet it correlates with cutter-induced machine vibration and TTS pullout conditions, but it's not the whole story about TTS pullout by any means. Steve, if you aren't cutting steel, I'm not surprised that you aren't getting chatter. I'm interested in cutting mild steel, and while I have had plenty of successes, along with them I've had plenty of struggles to avoid chatter and pullout for some operations, such as profiling with a reasonable DOC and shallow WOC. This is where machine design and setup differences are most pertinent, when intermittent high loading forces are imposed in repetitive and complex radial and axial loading directions. First vibration starts at light loading, then you get chatter at higher loads, and maybe you get TTS pullout somewhere in there too, or maybe you don't.
  2. #22
    Apr 2013
    99
    How tight not supper tight the cheapo wrench that came with the machine will do it
    snug then about 1/4 to 1/2 turn.
    but the threads on the drawbar and the collet have to be lubed
    it will cut steel with out chattering but using a rougher mill helps and 3/8 is the max tool for a finisher
    and it's better with 5/16 .
    Like Steve points out it's all in knowing the limitations of the machine and the tool
    a good carbide endmill also makes a difference when cutting steel 1/4 and 3/16 were my work horses in steel usually a ghuring variable helix.
    close to the same price as a decent hss tool in steel the tool smf is the limiting factor in aluminum it's machine spindle speed
  3. #23
    Jan 2007
    1332
    I have had no pullout issues with my Tormach PDB. I use at least 120psi with the PDB and adjust the drawbar on the Bellevue washers so that 120psi will just release the TTS toolholder. Also lubricate the Bellevue washers , drawbar threads, and R8 collet with LP250 antiseize LP-250 & LP-250F Anti-Seize Thread & Sealing Compound Bellevue washers are not a true spring and have sliding surfaces with friction so good lubrication is really required.
    Don Clement
  4. #24
    Jun 2012
    311
    Quote Originally Posted by Don Clement View Post
    Don Clement
    Don,
    Thanks for the input. I never thought about lubing the belleville washers. I run my PDB as tight as I can get it and still have my it release at 100psi, where my compressor kicks on. Keep the outside of the R8 collet lubed with antisieze and the inside clean, also keep the tool holder shanks clean. I have only had pullout when there was chatter.
    Dan
  5. #25
    Jun 2004
    6618
    One other area to check is the nose of the spindle itself. TTS seats there and if it is not true, it can bind a bit and require higher pressure to release cleanly. It's an easy spot to check and fix if actually needed.
    Before you remove any material from there though, make sure that it is trammed good.
    Lee
  6. #26
    Sep 2012
    1543
    It's funny we have 3 threads on basically the same thing going on at the same time.
    Uploading a video now, which will be part 2 of my test for collet pull out - My video is posted in the other 2 conversations, so I won't post it here too.
Page 2 of 2 12
  1. New Endmill Holder
    By whateg01 in forum Benchtop Machines
    Last Post: 10-04-2013, 04:21 PM
  2. 5/32 endmill holder
    By Hack in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 06-01-2009, 12:24 PM
  3. 1/8" shank endmill holder
    By CNCMike in forum MetalWork Discussion
    Last Post: 10-24-2008, 04:58 AM
  4. No Endmill Holder
    By DroopyPawn in forum Uncategorised MetalWorking Machines
    Last Post: 11-21-2007, 04:14 AM
  5. Endmill bit and holder.
    By ihkim in forum MetalWork Discussion
    Last Post: 07-26-2005, 07:38 PM
