588,656 active members*
6,186 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Mar 2006
    167
    I used to do work for a company, who have several V550T and V550TM machines.
    The rapid override does indeed work from the feed override as shown in your pdf. Ie 100%, 50%, 25%, and whatever is set in parameter 1421 (F0). Unfortunately this means if you want to run the machine with the override turned down, you also lower your feedrates.
    I do vaguely recall there being either a keep relay or an OPR switch which allowed them to set 25% "permanently". But that may have been a customisation which my company made at their request.
    Your other option would be to lower the parameters for rapid traverse.
    regards, Oz
  2. #22
    Jan 2010
    47
    Quote Originally Posted by Ozemale6t9 View Post
    regards, Oz
    Thanks for the info.
    I check out the keep relay.
    If I have to I'll change the parameter.
  3. #23
    Apr 2007
    43
    Re: Rapid Override?
    This is from the Fanuc 31i B-63944EN/02 Vol.2 of 2 parameter manual. A lot of the low numbered parameters don't change from old controls to newer so maybe this can help. See attached.
    1420
    Rapid traverse rate for each axis -Set the rapid traverse rate when the rapid traverse override is 100% for each axis.
    1424
    Manual rapid traverse rate for each axis - Set the rate of manual rapid traverse when the rapid traverse override is 100% for each axis.
    Attached Thumbnails Attached Thumbnails 1420.jpg   1424.jpg   1427.png   1420-1424_Notes.jpg
Page 2 of 2 12
  1. rapid override when door opened
    By steevo40 in forum Fanuc
    Last Post: 09-13-2010, 09:26 PM
  2. fanuc rapid override
    By sdb7311 in forum Mori Seiki lathes
    Last Post: 10-21-2009, 07:55 AM
  3. Please help with feed/rapid override parameter
    By Hermle UWF851 in forum Fanuc
    Last Post: 04-22-2009, 10:29 PM
  4. feed override and rapid speeds
    By rkremser in forum Mach Mill
    Last Post: 02-03-2009, 03:04 PM
  5. RAPID OVERRIDE
    By CNC_BOB in forum OKK
    Last Post: 06-02-2008, 11:34 AM
