588,211 active members*
4,076 visitors online*
Page 2 of 3 123
Results 21 to 40 of 54
  1. #21
    Nov 2006
    303
    Quote Originally Posted by zenbot View Post
    Those are really cool. My wife wants me to make some decorative panels for the house now. I've seen designs that look like water ripples with very natural wave patterns that would look really cool tool. Would be much harder to design though.
    Just depends on the software and amount of detail your looking for. Another consideration is weather you need to "panel" the tiles so the the edges are continuous. Which takes a little more time. But like anything, the more you do it the easier it becomes.
    Attached Thumbnails Attached Thumbnails ripple.jpg   3 panels high 2 panels wide.jpg
  2. #22
    May 2006
    954
    They are certainly eye catching. I believe vcarve has a feature in it that allows you to do that, just haven't explored it much. For this face machining I would say that I wouldn't use anything less than double-refined MDF (I prefer RangerBoard) or spraying primer on those panels would be like spraying water into dry soil.
  3. #23
    Jun 2007
    41
    Wow todd. that first picture is amazing. How did you make that? what software did you use?
  4. #24
    Nov 2006
    303
    I designed it in Adobe and modeled it in ArtCAM using the gray scale image. Came out pretty cool. The whole panel looks kinda like a germ.
    But that's what they wanted.
  5. #25
    Sep 2005
    1660
    Todd I'm curious as to how you sprayed the rayite? My understanding was it doesn't just work w/ any kind of gun??
    Curious..
    J
    JerryFlyGuy
    The more I know... the more I realize I don't
  6. #26
    Nov 2006
    303
    Its rayite 200 http://www.gypsumsolutions.com/newsc..._Rayite200.asp
    The proper spray machine is the cost prohibitive part. I got good enough coverage with a modified piston pump. But was a big mess to clean up
    fast as needed to keep everything from getting clogged up. Keep in mind I was just testing out the idea so the pattern was only 12x18.
  7. #27
    Nov 2009
    @Todd71 - I signed-on just to tell you how great I thought your designs look, and to ask whether you used the same technique for the "wave" design as you used with the "germ".
    The wife absolutely loves the Interlam product (starting to see it in many retail shops); however, it's not in the budget so I thought I'd try my hand. I have a local CNC shop that I source work to, but I'm not sure that I have the tools I'll need. I'm proficient with Adobe Photoshop/Illustrator and AutoCAD, but I have no familiarity with CAM software.
    The CNC shop may let me get on their system and play with ArtCam, but I doubt I'd be able to pick it up in such a short amount of time.
    Any suggestions for recreating this without a CAM tool, or possibly doing the majority of the work in AutoCAD, then handing it over to my shop to convert to a CAM drawing?
    Thank you in advance!
    -RM
  8. #28
    Nov 2006
    303
    "Any suggestions for recreating this........"
    Don't be affriad to make mistakes. Learn all you can from them.
    If you don't have time to do that, just buy it. :cheers:
    Takes time to do anything right.
    I've posted a basic idea of how to do the wave pattern at
    http://www.woodweb.com/knowledge_bas..._Patterns.html
    Good luck,
    Todd
    Web-site: http://www.innovative-accents.com/
    Blog: http://blue-collar-nobody.blogspot.com/
  9. #29
    Jun 2007
    7
    Does anybody have the artcam or cad file of that? I would love to do that as my ceiling panels in my basement.
  10. #30
    Nov 2006
    303
    I've got tons of them. And everything has it's price.
    Even then, if you got ArtCAM you should just do it.
    There's no reason to think you can't. Not trying to
    sound like an A-hole, and I'd sell you anything you
    want, but whats the point of owning ArtCAM if
    your not going to learn to use it?
  11. #31
    Jun 2007
    7
    I dont know much about artcam. Only did a few simple carvings with it. How would I go about doing it?
  12. #32
    Nov 2007
    197
    just when i think i've seen it all, i find this thread! very cool. now for some brainstorming
  13. #33
    Mar 2006
    489
    Those panels are first class. Nice work Ger and Todd!!
  14. #34
    Jun 2007
    7
    Thanks for the boost of confidence!!! I figured it out today. It turned out awesome!!!
  15. #35
    Nov 2006
    303
    Congratulations! Your smarter than you thought. Now for the fun part. Finishing them. Seal, sand, fill, seal, sand ......... The fun stuff:banana:.
    Cool pattern. :cheers:
  16. #36
    Jun 2007
    7
    Thanks again Todd!!! Im cutting the full sheet as I type. I will post some pictures of it when its done. The boss loves it!! I didnt think artcam was so easy to use. We just used it to cut foam letters for indoor decor signs. I program in autocad so I was looking into it way to much. It was extremely easy.
  17. #37
    Nov 2006
    303
    Sometimes you just got to step back and think about it. No worries. But the jobs not done till you hang them. Light them up. And then you can pat yourself on the back for a "Job well done". Are you just going to screw them into your ceiling?
  18. #38
    Jun 2007
    7
    No, I going to replace my 2x2 drop ceiling pads with these. I got our other CNC working 24 hours a day to cut all of them. Man it takes forever.
  19. #39
    May 2005
    2502
    These panels are very cool!
    Thanks for sharing them.
    Best,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
  20. #40
    Sep 2009
    30
    Looks very similar to what I used a few years ago to make a display room counter.
    Was simple enough got a black and white sketch of sand in bmp converted it to dxf. Created lead ins and lead outs to give it a nice "flick' then changed the depth betweedn some cuts to make it look like the ovean had been running over coarse sand
    We used a custom 70mm bit rounded to do these as it worked out a lot faster to process as well as the cuts didnt look defined and there werent any flat bits either.
    If you want to take these the next step you can cut 3mm slits though the back half of the board every 15mm. Then shape the top of the board.
    This can then be steam heated and wrapped around a counter or similar. Just be carefull when you do this as to mauch will ruin the MDF theres a fine line between ruining the board and making it work well.
    Will try find some pictured of the display
Page 2 of 3 123
  1. Replies: 0
    Last Post: 01-21-2014, 06:07 AM
  2. Replies: 0
    Last Post: 01-14-2014, 05:50 AM
  3. Trying to do V cut LED panels
    By Milenabm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-17-2013, 09:24 PM
  4. RFQ for aluminium panels
    By Surp in forum RFQ (Request for Quote)
    Last Post: 10-21-2012, 04:23 AM
  5. textured panels
    By cabnet636 in forum Camaster
    Last Post: 06-18-2011, 01:05 PM
