587,913 active members*
3,741 visitors online*
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    15362
    Re: Milling spheres?
    Quote Originally Posted by Jarith1993 View Post
    Here is the attached image. Of a slug that someone else has turned so far.
    And the ball im looking to make is a 30mm ball (a perfect sphere with no holes etc to attach a stem)
    I’ve seen a few videos of people rough lapping on machines following a chamfer and pressing process.
    But ideally I want to do this on the cnc.
    The cnc we have at the factory is a haas sl20 if you’re wondering.
    Just as Jim has said, make some soft jaws they only have to hold around 60% of the diameter , cut the waste off and then turn the rest of the ball
    Mactec54
  2. #22
    15362
    Quote Originally Posted by deadlykitten View Post
    this is a fact, from a plant : technology for crafting balls involved forging from dia~25, and hot forging from dia~60 to over100
    forging operations are followed by turning in 1 or 2 steps : removing burs + kind of prefenish, before grinding operations
    okey, now what ?
    Please show us this primitive plant doing this turning operation, it does not matter what size ball is need they are either hot forged or cold headed then Ground from that point on
    https://www.precisionballs.com/Giant_Balls.php
    Mactec54
  3. #23
    Jun 2015
    4160
    hy jarith
    We’re having trouble holding the sphere for the 2nd operation
    what kind of trouble ? what is your fixture for the 2nd operation ?
    i want to turn it to a tolerance of around 2 thousands. But I’d be happy with 5 thou all the way around or even more.
    2-5um ? hmm ...
    However that isn’t my main aim at the moment, holding the work for the 2nd operation is my main concern
    no, no, you should not see them different ... i mean, you have to "link" the "desired tolerance", with the "stability" of the fixture; if you wish to achieve a rough tolerance, machine setup will be fast, but, for a more precise tolerance, you need to invest more time in preparation
    so, what quantity do you need, and what tolerance is allowed ? or is just an experiment, see what happens, etc ?
    ok, now, i will share a few things :
    1) in the 1st operation, you may encounter a not-so-nice finish towards X0, because the machine has to increase the rpm too high, beyond it's limits, so, in the middle, there will be a spherical cap, with rough surface roughness; does this bother you ? do you wish to minimize this effect ? if yes, then pls check footnote *1 below
    2) X axis backlash may be within 2-5um, so you may not need to worry about it now; if axis backlash is > 5um ( or whatever value you consider ), then you need to discuss with your machine dealer, about the posibility of managing axis backlash by parameters / code; if it is not possible to manage the backlash, then you will have to map it "longhand", thus by g-code, and hoping that it will work
    3) for the 2nd operation, if you use soft jaws, and still wanna achieve 2-5um tolerance, pls look at attached image :
    ... left : yellow represents the machined surface in 1st operation
    ... right : yellow represents the machined surface in 2nd operation
    after clamping the sphere ( 2nd operation ), and before cutting, check the fixture tir : is it <2-5um( or whatever value you consider ) ?
    ... if yes, then you can continue, and check tir periodically ( like once at 4 hours, etc )
    ... if no, then you can not continue, since fixture stability is not enough; i can share infos about clamping with low tir, like few um, but this requires more time seting-up the machine; even if you use soft jaws, with low hidra pressure, your chuck has to be in good condition, and the machine size has to be small, because, hidraulics, even at low pressure, may generate a force big enough to mess up a tir, way beyond 2-5um; again, pls say if you need a solution to improve tir for 2nd operation; check a brief info in footnote *2
    4) 2nd operation will have to manage the "meeting point", thus, somehow, you will need to tangent the surface from 2nd operation, with the surface from 1st operation; check the details in right image : this requires a hard material, and a sharp tool, so to minimize the difference; if material is soft, and/or tool is not sharp, the difference will be more visible; i don't know, in the end, polish it a bit ?
    kindly
    hy mactec, if that thing is working for them, then is ok
    in that image that you shared, it seems that there is the "deflashing" operation, that removes the "big bur"; maybe that it can handle more than 1 sphere at a time, maybe it can perform faster than turning, maybe those cast iron plates will last for a looong time, i don't know ...
    in that link, it seems to be an automated solution, that does " grinding / lapping / polishing " ... but look what is there " We usually machine the blanks ... on spherical turning machines, but cast ingots or formed and welded hemispheres can be the raw material. " - it seems that that custom-cnc can do rough operations, but is preffered to do the roughing before, on another machine
    so, i guess that is not so "primitive" to have a machine only for rough turning ?
    please, do you have a video with this machine ? kindly
    *1
    you need to map your rpm range across the sphere, see what happens, in order to minimize the " dirty " cap surface; in other words, you have to keep the cutting speed constant for as long as possible :
    ... try a lower V ( M/min ). so to delay the moment when the machine reaches it's spindle limit, and, as a result, the cap surface will decrease; there is a balance, because :
    ...... if V is decreased, overall surface quality may get lower, because finishing requires speed, but, the cap surface may be barely noticeable
    ...... if V is increased, overall surface quality may improve, but the cap surface may increase and look nasty; this balance has to be found by running trials, and it depends on material and tool
    ... instead of a turning knife, you may use a round-end-mill, so to stabilize even more the cutting speed : as a result, you no longer deal with the "cap" problem, since M axis can keep it's rpm constant regardless of X, but, for this to work, you may need to keep the spindle runing in S mode, not in C mode, thus you may need a machine interlock; if you rotate the spindle with C axis, motion will be discontinued, since you can not achieve constant rpm in C mode, so, you need to run continuosly, in S mode
    *2
    somekind of hollow semispheres, one being machined in the spindle, and another being inside the tailstock; this setup removes the "noise" caused by the hidraulic pressure inside the chuck ... however, it requires a smooth tailstock; if tailstock pressure is too big, than "noise" re-appears; in such a case, you may tighten the tailstock mechanically, using a screw + nut system
    this "noise" represents the position shift range, caused by the hidraulics; if you remove/lower the hidraulics, you will remove/lower this "noise"; does this makes sense ?
  4. #24
    Jun 2011
    692
    hy jarith
    2-5um ? hmm ...
    Thou normally refers to thousandths of an inch.
  5. #25
    Jun 2015
    4160
    hi skrubol, i don't know, in post 19 he sais that dia should be 30mm ...
  6. #26
    Jun 2011
    692
    In some areas is it common to use 'thou' to describe thousandths of a mm? I've never heard it used that way.
  7. #27
    Jun 2015
    4160
    hi mactec, i have been thinking about what you said, and that machine that you shared, and i am still pretty curious about it
    some multitasking machines can rough + finish + grind, maybe they have double wipers, etc, but their precision stops at 3rd digit, or a fraction of it
    the machine that you described, seems to be able to rough + grind + lap + polish, and this means a more wider spectrum
    if a machine is roughing big time, i no longer trust it for smooth finishes, and, in some places, some machines are used only for roughing, while others only for finishing; a spindle which roughs big time, is not going as smooth as a spindle that only does finishing jobs
    in some places, rough heavy machines are at 1st floor, and light finishing is at 2nd floor; i am just saying
    i am curious about how that machine works, even if the description is pretty ok; maybe roughing is on one spindle, and grind/lap/polish in another place, but still inside the machine / kindly
    ps : hi skrubol :wave:
  8. #28
    15362
    No sure what you are missing there are more than one machine, First the blank is cold headed, Machine ( 1 ) they are deflashed machine ( 2 ) then soft ground Machine ( 3 ) then Heat treated, then descaled, then Ground Machine ( 4 ) then lapped Machine ( 5 ) all in different machines of the same type for each operation
    Mactec54
  9. #29
    Jun 2015
    4160
    hi, here : " This extremely versatile machine will go from grinding to lapping and then to polishing with only a change of tooling and small variations in speed and pressure ... We usually machine the blanks for these giant balls from wrought or forged billets on spherical turning machines, but cast ingots or formed and welded hemispheres can be the raw material. If the balls require hardening, we heat-treat them after machining "
    from here : https://www.precisionballs.com/Giant_Balls.php
    that is a nice piece of equipment / kindly
  10. #30
    15362
    That is because they are doing small runs and large balls, they still have to change the Grinding Disc's for each operation, as in production they use multiple machines setup for each operation, it's still the same machine as any of the other ball manufactures are using
    I posted about that company in other posts
    Mactec54
Page 2 of 2 12
  1. Need machine spheres
    By jeremy0203 in forum Employment Opportunity
    Last Post: 10-30-2010, 09:55 PM
  2. Need g-code for 4 axis semi-spheres.
    By jaru-eri in forum Mach Software (ArtSoft software)
    Last Post: 04-30-2008, 02:49 AM
