Okay, so what can create backlash on only belt driven machine? Loose belts? I'll tighten them then. I'll make sure everything that even remotely touches the motor is fixed in place.
By the way, do I understand this correctly? I have a table that has ability to be adjusted (it's on three legs, two fixed and one adjustable) but then I lay a sort of crate on top of this, where the material can be supported to be cut. IF they're not perfectly, dead level - could *that* make the eliptic issue I was talking about? Because I can't say with 100% certainty I had the machine dead leveled back then. I was focusing on motor movement too much to be 100% certain.
I want to thank you again for your time and letting me bounce questions off you - I will be in my workshop tomorrow/ day after tomorrow and I will make the necessary adjustments, then come back to you.
