Originally Posted by
mflux_gamblej
I've trashed 4 x 1/4" and 1 x 1/2" endmills on the same workpiece.
My most recent attempt was:
1/4" endmill, 3850 RPM (252 SFM), 10.78 in/min xy feed (0.0007 in/tooth), 7.7 in/min z feed (0.0005 in/tooth). Step over is 20% of tool diameter (0.0500"), plunge depth is 0.0250".
I've also tried around 1000 RPM, around 4 xy feed, 1 z feed, the tool actually died much faster this way. The material is 304 stainless steel, the cutters are TiALN coated carbide from MariTool.
My mill is an old interact 1 mk 2, 9.5 HP, workpiece is clamped hard to the table with a waste plate of Al underneath so I can mill through into that. I get a lot of chatter at slightly lower RPMs (around 3000-3300), almost no chatter around 1000 RPM, and pretty much no chatter up at 3850 RPM.
