588,506 active members*
5,797 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Is Automation Technologies still the go-to source?
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    Nov 2005
    222
    Re: Is Automation Technologies still the go-to source?
    The most common formula for calculating the voltage to run a stepper is 32 times the square root of the inductance. So using 2mH that would be about 62 volts but you are limited by the drive that is rated at 50. I used 381oz steppers with an inductance of 2.8 with is 53.5 volts on my X & Y of a mill using a 48 volt power supply. I have plenty of power and enough speed for a mill.
  2. #22
    Sep 2018
    9
    Quote Originally Posted by rcheli View Post
    Interesting.
    Looking into it, the NEMA23's on my G0704 appear to be 2.2mH and rated for 6.0A.
    I am running them with a 48V supply (more or less, this particular supply seems to be open-loop and its voltage varies a bit depending on load, ...).
    This metric would give ~47V.
    I am generally running them at 20 IPM, with.
    IIRC, ~ 10 revs/inch; or ~200 RPM for X/Y; and ~ 32 revs/inch or ~ 512 RPM for Z (IIRC, it was 5 TPI for X/Y with 2:1 reduction, 8 TPI for Z with 4:1); could be wrong here, I am going off memory.
    But, as noted, 20 IPM was chosen as this is the speed I could run it at without getting any lost steps during a sequence of rapid moves (would issue a sequence of rapid moves and verify that the mill was still in the expected place).
    The 570 oz-in NEMA23's on my lathe are 2.5mH, rated for 5.0A. I ended up running them at a similar speed.
    I still haven't extensively tested this, but it appears to work.
    There is a 2:1 reduction (due to the lathe's gearbox); working backwards, it seems to be 28 revs/inch, or 14 TPI on the leadscrew (may need to verify), implying ~ 560 RPM.
    At 1:1, the torque requirements (to move the carriage) tend to overload the motor (could require closer to ~ 1000 oz-in?).
    In both cases, it seems I am running them a bit under their rated current, but then again this limits the motors getting overly warm.
    The NEMA34 I am using as a spindle is 5mH (as wired), working out to around 73V.
    As noted, it is rated 8.8A, but I am currently running 5.5A (and it runs decidedly warm), but is apparently probably OK (after a few minutes, reaches a temperature of ~ 40-50C or so, then mostly levels off).
    The way that the Automation Technologies page said to wire it would make it have 20mH, but whatever voltage the KL-11080 is putting out doesn't really appear to be enough to get particularly high RPMs (this metric gives 143V, and bridge-rectified 110VAC could theoretically give 170V, so dunno...). Extrapolating from other patterns, the driver seems to perform more like it is operating at 70V than would be expected if it were operating at 140-170V.
    As-is, running the spindle at 250 RPM, is ~500 RPM on the motor.
    If it were 140-170V, I would expect a wider RPM range than this (with a motor at 5mH).
    I am not sure the voltage the driver is putting out (whatever it is putting out is seemingly something the multimeters I have are unable to deal with, granted all I have on hand are the Harbor Freight / Cen-Tech DMMs).
  3. #23
    FWIW: I have been off experimenting with using a NEMA34 stepper as an alternate lathe spindle motor ( https://www.automationtechnologiesin...34h2160-62-8a/ ), with the KL-11080 driver.
    What it basically comes down to is that the bigger the stepper, the slower it'll spin. No matter how good the drive is. 500 rpm is the max you're likely to get out of anything over 1400oz.
  4. #24
    Dec 2013
    158
    The 640ozin Nema 34's are a pretty good combo on the g0704, way better than the 570 nema 23.
  5. #25
    Dec 2010
    201
    Well, right now, it is looking like I'll just go for the 2x23, 1x34 kit with the 570 motors from Automation Technologies. I'd like to do 34s all the way around, but frankly, it is probably right to go with the 570s... The control will likely be the Centroid.
    I may go with larger mounts in the future if I upgrade to the quieter Clearpaths. I don't know.
  6. #26
    Dec 2013
    158
    Thats ok. With 5mm pitch ball screws the 570's loose a lot of torque at about 100ipm. This may limit your rapid speeds. Its why I changed from the 570's to the 640's.
    Quote Originally Posted by bogiestl View Post
  7. #27
    A 6 amp 460oz Nema 34 would probably be a decent upgrade over the 570.
  8. #28
    May 2008
    1185
    The 640 look good with 2,2mH of inductance.
    You generally get with a 5 TPI screws about .8 pounds of peak force from every once inch of torque.
    So a 570 will give about 456 pounds of force and the 640oz 512 pounds for a mill that weighs 250 pounds.
    youtube videos of the G0704 under the name arizonavideo99
  9. #29
    Dec 2013
    158
    The 570 ozin nema 23 drops to ~100 ozin at 550 rpm which is about 110 ipm with 5 mm ball screw. In contrast the 640 ozin nema 34 (KL34H280-55-4AT) has ~250 ozin at 550 rpm. More than double the torque. I had problems stalling at 100ipm rapids with the nema 23 this matches the torque / speed curve. I haven't had a problem with the nema 34 so far. Theres more to consider than the holding torque.
  10. #30
    May 2008
    1185
    Well the 6.3A 640 looks to be the fastest stepper of all the steppers he has. The driver looks like a standard one. I don't know if the digital drivers have copied Gecko drives "drive Morphing" function which would give even better high speed performance.
    Something is wrong with the 570 oz torque curve. All the stepper should behave close to the same. Even power in the chopper current limit range then a 24DB roll off after that. I don't understand why the 570 falls faster. I think the driver was having a hard time controlling the resonance the stepper.
    Either way the 640 looks like a winner. I thought it was 3MH I must have been looking at the wrong one.
    Still for the smaller mills the 570 is the best Nema 23 mount. I don't know if the closed look will out perform at higher speeds but I do have both on hand so it night be a fun test.
  11. #31
    Jan 2018
    1516
    Bit pricey for me especially with the con-men in the import V.A.T. offices. looks a nice unit though.
    I think I've found something I can live with for my new one as a starter then look at servo's later depending on how it goes:
    https://www.ebay.co.uk/itm/German-Sh....c100290.m3507
    Shows 4.1mh inductance and under the earlier formula (square root MH x 32) comes out at 64.8V which seems to be a close enough match to the psu's (60V). At 1090ozin if I get half out of it it will do me. 2000mm/min (78in/min) looks to be about 400rpm on a 5mm screw which is adequate. Even 1500mm would do.
    Took me a while to find something reasonable, a heck of a lot of motors are above 6mh inductance.
    Some of the 8 wire units can be wired in such a way to get them down to 3.5 but I can't be bothered with them. I'm bound to wire them wrong
  12. #32
    Dec 2010
    201
    Well, speed isn't the overwhelming goal here - Being able to push the button, and then come back later is preferred - so if I have to run rapids slower, that's fine.
  13. #33
    May 2008
    1185
    You should run then at 80V.
Page 2 of 2 12
  1. Impressed with Automation Technologies
    By Miax in forum Automation Technology Products
    Last Post: 09-21-2015, 08:50 PM
  2. Automation technologies lasers, any input?
    By talonosi in forum Commercial Laser
    Last Post: 06-17-2015, 10:11 PM
  3. CNC4PC and Automation Technologies
    By DRock in forum CNC4PC
    Last Post: 02-18-2015, 02:33 AM
  4. Automation technologies ball screws
    By kuyote in forum Benchtop Machines
    Last Post: 03-21-2013, 11:36 PM
  5. Automation Technologies (Keling, Inc)
    By kerrycorcoran in forum DIY CNC Router Table Machines
    Last Post: 10-21-2012, 05:50 AM
