588,219 active members*
4,017 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > X3/SX3/G0619/G0463 > jossa's G0619, going CNC one step at a time
Page 2 of 4 1234
Results 21 to 40 of 71
  1. #21
    Dec 2013
    159
    Re: jossa's G0619, going CNC one step at a time
    the problem is that i am going for CNCFusion's kit.. and he uses nema 23 on X and Y axis .. and a NEMA 32 on the Z
    AND it is direct drive...
    i am confused what to do now.. maby i have to stick to "just" plain digital steppers..?
  2. #22
    Apr 2009
    28
    yes digital stepper is a good choice. Better than standard stepper motor...
  3. #23
    Dec 2013
    159
    the problem is that i need a stepper motor capable of around 7 NM on the NEMA 32 and around 3,5 NM on the NEMA 23 and i cant find that in the Leadshine closed loop easy servo lineup..
    any other manufacturers of the same type of system? (closed loop)
    if not, my backup plan is to revert to digital steppers
  4. #24
    Dec 2013
    159
    does anyone know what size steppers is required on the different axis?
    i plan on using a CNCFusion deluxe kit
    http://www.cncfusion.com
    X and Y i plan on using 570 OZ-in / 4NM
    Z i don't know how much i need 920 OZ-in / 6,5NM maby?
    anyone have any info on this i would appreciate it
  5. #25
    Apr 2009
    28
  6. #26
    Dec 2013
    159
    Thanks gozos! it is helpfull, i have searched but could not find any relevant info..
    also i made another work bench.. need to clean up my part of the cave and finish the top part of the table so the mill is enclosed.. anybody got any good ideas?
    thinking of using plywood and epoxy coating
    Attachment 241288
    one more also!
    I have now ordered a KFlop and a KMotion to control and run my steppers.. steppers soon to be ordered...
    Attachment 241294 + Attachment 241296 = Attachment 241298
    Dynomotion KFlop
    Dynomotion KStep
    i have high expectations for it! and also Tom over at Dynomotion has helped me with finding out what would work best with the unit, a big thank you to him! =)
  7. #27
    Apr 2009
    28
    In this document from syil you can find this:
    "Stepper motors:
    Our X and Y axis stepper motors are a NEMA 23. They have a hold-
    ing torque of 260 oz/in. And consumes 3 amps per phase.
    Our Z-axis stepper motor is a NEMA 34 They have a holding torque
    of 460 ounces per inch. And consumes 3 amps per phase.
    And it seems it is direct coupling, no belt...
  8. #28
    Dec 2013
    159
    gozos @ Re: jossa's G0619, going CNC one step at a time
    "Stepper motors:
    gozos you are a life saver!
    i think i will order this 570 Oz motor for my Z
    and for X and Y i will use this 370 Oz motor
    if that was good enough for syil then it should work on my machine
  9. #29
    Apr 2009
    28
    if you buy cnc fusion kit you need nema 34 for the Z...
  10. #30
    Dec 2013
    159
    Small-Mill Deluxe CNC kit PREMIUM BALLSCREWS
    This Kit includes all the hardware for a 3 axis conversion. Two NEMA23 motor mounts for the table, and a NEMA34 mount for the Z axis, lovejoy couplings, timing belt and pulleys on Z-axis, locknuts on the X-Y ballscrews, ANGULAR CONTACT thrust bearings for X-Y axis, PREMIUM ZERO BACKLASH BALLSCREWS, and metric cap screws & bolts. Nema23 motor mount for Z-axis is available. You MAY need to modify your mill to install this kit. DELUXE BALLSCREWS HAVE A 5MM PITCH.
    $969
    so i think someone else has had the same idea before me...
  11. #31
    Apr 2009
    28
    so no problem!
  12. #32
    Dec 2013
    159
    yea i think this might actually work!
    and the controller is capable of handling 5A per channel so i can go bipolar parallel and use 570 ozin/ 4Nm motors on all axis without problems!
    only thing is i don't get the closed loop that a leadshine would give me..
  13. #33
    Dec 2013
    159
    got some new toys!
    first i have gotten a IP66 enclosure for my electronics, Schneider Electric 600X400X200
    Attachment 241698
    and i have just received the Kflop and Kmotion..
    (Kflop are going to be stacked on top of Kmotion)
    Attachment 241700
    the place that i was going to get steppers from had a bug in the checkout so i could not place an order.. so that is on hold for now)
  14. #34
    Dec 2013
    159
    Got both the Kflop (rev. 1.3) and the Kstep (rev 1.2) mounted together.
    so far i love the hardware, the green terminals are detachable, making it much easier installing tthe cables, nice detail!
    also i got a "free" USB cable included in the deal.. nice
    Attachment 241758
    Attachment 241760
    Attachment 241762
    Attachment 241764
    so now i am reading trough the documentation on the hardware...
    and to be honest it is a bit difficult to know where to start (they had included some printed documentation in the parcel tho)
    and as far as i can see i need to download the latest software from here and after installing that, i have to check and see that my firmware is updated..
  15. #35
    Dec 2013
    159
    ok.. i have not updated any firmware yet.. (to afraid :P it kept saying i could brick the unit.. soooo... no )
    the good thing is that i found out i need to disable driver signature checking routine on my WIN 8.1 pc.. so after doing that and installing the usb driver for the board, it connected! (confirmation in console)
    so now i am connected to the Kflop, and i have 5V light on both the units, not sure if that is good considering that it is powered from a usb output on a computer but i can mess around in the programs.. now i need to read more manual to find out what is next.. (i think i need to define the outputs for my steppers and such but i will try to read the manual and find out what is next)
  16. #36
    Dec 2013
    159
    the enclosure is taking shape now..
    i have also started painting it but i forgot to take pictures of that.
    Attachment 242008
    Attachment 242010
    now my biggest problem is what to do with the front, i need something that is easy to access, but water thigh enough to withstand the spray of coolant from the machine.
    i have also gutted the head and the back cover with all the controllers and cables..
    going to move the motor controller into the same cabinet as the controller and drivers are.
    Attachment 242012
    when i get the machine up and running i am going to make a face plate for the front to tidy it up a bit.
    i am also contemplating to incorporate a column brace into the design before epoxying up the table.
    incorporating a plate underneath the machine and a couple of steel pillars on the side, parallel to the column for added stiffness
  17. #37
    Dec 2013
    159
    just got my 3 steppers..
    soon i have my power supply and then i can start testing the motors and begin building the control cabinet
    Attachment 242608
  18. #38
    Dec 2013
    159
    well i got some work done, started painting the enclosure in a machine gray color.. i think it looks nice. =)
    Attachment 242714
    Attachment 242712
    (i don't know why the picture is on its side, on my computer it is the right way around)
    Using nothing but the best, biltema! :P cheap but good.
    Attachment 242716
    when i finish everything i plan on making some large windows out of 6 mm Plexiglas in both doors and on the side..
    anyone have experience with using that? i don't know how well it will stand up to the chips and coolant..
    next is making doors and a slanting table under the mill.
  19. #39
    Apr 2009
    28
    Good work!
  20. #40
    Dec 2013
    159
    thanks gozos.
    i now see the cost and time is way more then anticipated, but it is fun
Page 2 of 4 1234
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 4
    Last Post: 09-10-2013, 04:52 AM
  3. Kflop Dir / Step setup time
    By BobKinsman in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-16-2012, 12:10 AM
  4. Step/Direction pins should be Step FWD and Step BACK
    By rayscott in forum Mach Software (ArtSoft software)
    Last Post: 02-10-2010, 12:57 AM
  5. Step time values for 990H
    By svenakela in forum Servo Drives
    Last Post: 09-23-2009, 09:36 AM
