588,603 active members*
10,067 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Apr 2006
    101
    Try new gas
    Hey D,
    Try new gas.
    I've seen two different bottles of gas that did not contain 100% Argon. (but should have)
    When I had the laser business it was easy to check (we'd just squirt it into a vacuum, ionize it, and look at the spectrum) pure argon produces a distince lavender glow consisting of spectral lines including 488 and 514nm (and lots of others).
    CO2 and Nitrogen both seem to have a way into welding gas mixes and both will kill your welds.
    I also second the recomendation of Helium mix. Remember that this kind of welding is sometimes called "Heli-Arc"
    Best regards,
    Barry
    my projects:
    http://www.barryfish.com
  2. #22
    214
    sorry
  3. #23
    Apr 2006
    101
    No apology required
    Mortek,
    Your focus was not bad and was correct and imformative.
    "I guess no one understands what I was trying to convey here. I use straight helium and dc straight polarity to weld thick aluminum because it ionizes hotter than argon. I am not the inventor of this process, I was simply passing it along to those who have lower amperage machines as a means of welding thicker cross sections.
    Two reasons it runs hotter:
    DC (tungsten negative) sends the ion stream in the direction the work.
    AC (typical heliarc) heats the work 50% of the AC cycle and the tungsten 50% (the other 1/2 cycle) of the cycle.
    Second reason:
    Helium is a high (electrical) resistance gas which yields signifiacntly more heat compared to Argon.
    Pure helium is tought to keep "lit" so it's mixed with argon which lowers its resistance.
    my projects:
  4. #24
    Jun 2005
    476
    Mortek, those are some impressive welds! I guess I'll have to give it a try with DC. Do I need to use HF start?
    Barry, I'll get some Helium on my next trip to the welding supply shop and see how it does.
  5. #25
    Apr 2006
    101
    Ar He Mix
    D,
    Get the 50-50 mix. Don't just take the first dufuses answer at the welding supply if it sound wrong.
    There is a lot of info on mixes at http://www.praxair.com/praxair.nsf/A...2570A60020CFAE
    B
    my projects:
  6. #26
    Quote Originally Posted by Mortek View Post
    Sorry,
    Those are pictures of the same bead, shown before brushing and then after.
    Yes, and its a nice bead.....but the first one needs to be brushed!
Page 2 of 2 12
