hey has anyone used these machines to engrave on chrome or polished aluminum?
If so what steps do you have to do the make it work? ie cover with paper, lamp black or what not.
How many watts would you need to cut tin foil type thickness in metal? (don't answer unless you done this, as I realy don't need speculation)
Also Sid_steve when you engraved the mirror/glass for Dairmaid did you run the laser over the whole surface or just on the features?
if you ran it over the whole features, why? and will it let you just engrave on the image itself?
edit: i looked at the image more thuroughly and I see that it was run as a negative image. Can you run it as a positve image where just the bird and leaves are engraved?
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
