Also when the spindle loaded it don't draw much .
I measured the voltage to the vfd input and it's depends if other components work at the same time ! If the vacuum cleaner off (not working) the Voltage supplied to vfd is ~215v, and if the vacuum cleaner work with full power, the input voltage to the vfd is ~199v ... I didn't measure the current at the vfd input ... I will do it when I near the machine - probably Thursday
... But is that normal the voltage change in vfd input ?!
Sent from my A0001 using Tapatalk
