Yes almost ,some of these are larger and have 3 ceramic bearing and not 2 steel bearings AND SINGLE PHASE OR TRIPLE PHASE inverter,but HSD is from Italy
No, its really not that bad at all on price for what you are getting , if you email me i will give you the price
CNC router frame
Bearing housing for frames, double and single bearing
nice looking.
whats a complete frame going to run?
they start at $300 cdn
have the
20x36 up to 48
24x24 up to 48
36x36 up to 48
these look very well done
Y axis with pockets for rails with end screws
Bearing housing and motor mount taped holes
1/2 INCH ALUMINUM
whats the cost of a 24x48 frame? 48x48 frame?
24x36 travel $350
24x48 travel $375
When you say 2005-4, what does the 4 mean? I'm a bit of a noob when it comes to this stuff.
Which size ballscrews would people recommend using on a 24x48 frame? I don't know what difference the diameter makes.
While I'm at it, I've got a few other questions I'm hoping someone can answer. What is the difference between SBR and TBR blocks? What size rails should I be using on the 24x48 frame or does this all depend on what you want?
Are all of your linear bearings round or do you have any square bearings?
4 turns per inch
Should use 2005 after 700mm length
On 24x48 travel you would 30x52 inch ballscrews , depends on where end bearing housings are
SBR has shorter and thinner support profile and bearing house and a lot lighter
2433 .travel ..$335
Frame is 30x36 without motors or mount
END FRAME 1/2 inch
Y upright 1/2 inch
1x2 Aluminum profile
X 20MM RAILS
4 20mm bearing and blocks
Y 16MM RAILS
Bearing house 6200 w/ double sealed bearing $15.. 4 per FRAME
Motor mount $16 2 per FRAME
X 900mm 2005 ballscrew with nut $ 120
Y 750mm 1605 ballscrew with nut $ 100
machining 20$ each
Ballnut Bracket $20
3/4 Y uprights $25
2445 .travel ..$350
Frame 30x48 with out motors or mount
END FRAME 4 "wide 1/2 inch
Y upright 1/2 inch
X 20MM RAILS
Y 16MM RAILS
X 1200mm 2005 ballscrew with nut $ 138
machining 20$ each
Ballnut Bracket $20
3/4 Y uprights $25
3/4 X end frame 5' wide $25
40mmx80mm ( 1.57" x 3.14" ) profile $ 80
X axis 2 1400mm TBR fully supported rails 20mm with 4 bearing $ 160 for 4080 profile only
Flex coupling $10 each
is there a Z azis for these?
Yes there is , we are just finalizing it now with 5" and 8" travel
Also have bearing housing and ballnut bracket for ACME screws
Router Camparison
