thank you for answer. where is speed control knob? maybe you have manual?
no errors flashing on relays and internal fuse. with electrical all fine we checked.
well that's not really off to a good start haha
trying to drive this machine from here would be like trying to drive the lunar lander on my cell phone!
does your controls look like : (I have 720)
tis the one in the Middle set of dials under the keypad/board
left dial is spindle speed control, right is 'whole' machine control (probably has proper name)
my machine looks similar us yours. i can move x,y,z axis. but cant start reference.
i found speed control.
i have manual in German language. i translate where is writing about reference and do according to the instruction but reference not starting.
you need to go : Mode 3 (MDI MODE)
enter with keypad "M100" > LF Key (enter) > Cycle Start (directly above dials last/4th of the 4 button set - Square arrows 1 in the middle)
edited with MSpaint
steps :
1 : MODE
2 : 3
3 : M100
4: LF
5: CYCLE-START
this references the machine and sets everything to zero - must be performed everytime you initialise/turn it on
takes about 30 seconds to complete the cycle
it will check xyz and rotate the tool changer to T1
can you take picture of screen when referencing starting?
i going to mode 3 and pushing start button, when # button and ref button according to instruction.
what means M100 ? i do not found it in instruction. maybe i just pass it
my machine old to and never updated
but its different starting from yours. i take some pictures. when reference should starting.
maybe first need load some program before referencing?
i put some pictures there
3.jpg picture by mar404 - Photobucket
2.jpg picture by mar404 - Photobucket
maybe anyone can help? reference is not starting. maybe first of all need load some program and after start reference?
I have a record 2 scm with this problems,
The screen reads *PC*
CHECKSUM RAM
PC CHECKSUM
What is error.Do I have to change the battery?
I already try to check the machine
When initialise the screen reads no utilities in ram
I can see the parameters
Please help any one the correct way
I just bought the machine scm record 2.
There were some wiring wrong fixtures on the input card which burnt the cards.
I have already changed the cards and rectified the problems.
Some one fixed the ac supply to the dc card which cause the malfunction.
I can send the pics only on next week monday
I have some pictures from the machine
these are the pics.Pls help
Can someone help me please
I have lost the parameters of NUM750 ROUTRONIC
and I have no backup disks
my email address: [email protected]
Please help my NUM 750 on BP Week 05 machine in manual mode works with 4% of the movement can be key to further accelerate the movement but when I switch on automatically then the movement of 0% and will not even go to a reference point off alarms include beetroot start bright green light flash on the screen REF aCTIVE START PROGRAM 9998% BUT MACHINE STOP
