588,244 active members*
4,314 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Squareness error compensation
Page 2 of 2 12
Results 21 to 39 of 39
  1. #21
    Mar 2008
    288
    Re: Squareness error compensation
    See Attached Files for A2100 Batteries and Power Supply info...
  2. #22
    Jul 2020
    38
    I had a change to play abit more.
    I have a part where i circular milled diameter 296mm and diametee turns out 0.04mm smaller in Y direction (0.02mm per side)
    I checked the balance and gain,my machine is in swedish so not sure if i got it right. I adjusted "balanskompensering" til KV was same in both directions
    I did notice the X had value +0.72 (adjusted to 0.6)
    And Y axis -1.12. (Adjusted to -0.65)
    This made no difference in the circularity
    I wonder if this has to so with my squareness error between X and Y but cant figure out what happens really?
    I cant feel any mechanical backlash where machine change direction.
    If i mill a small hole it is good.
    Does the 0.013mm squareness error across 500mm cause this?
  3. #23
    Jul 2020
    38
    Ok i might have measured abit sloppy.
    I would say a diameter of 300mm is 0.02mm smaller in Y direction.
    Meaby it was abit better after the Kv got dialed.
    I have found something i think
    In the pitch error compensation Y axis has really small values. Like 0.002
    The X axis has bigger values across the table. Something like 0.012
    Could it be that it is over compensated in X?
    Why would one put values in there when it has scales?
    Meaby one time the machine was sloppy in X axis..
    I have replaced the coupling at the motor and motor has been overhauled by siemens tech sometime.
    I dont really wanna mess with the table as i dont understand how it works, gwood do you know?
    I see it has increasing values from 0 to 510 and then values to put + - and so on...
  4. #24
    Mar 2008
    288
    Kwirk,
    See Attached file for Table Flatness and Tram. This needs to be checked First.
    Make your tests with a cold spindle at start up.
    The Tables were done in the Factory with a level machine table using a laser measuring device.
    A ball-screw or linear scale may not be exactly parallel to the linear ways producing errors.
    The Y-Axis also has Thermal Compensation due to the fact that the Spindle Carrier grows out and away from the carrier as it heats up.
  5. #25
    Jul 2020
    38
    I would say the tram is good.(it was atleast lets see)
    When i got the machine it was really bad in X direction
    So i spent alot time dialing it in. I did this at fairly big diameter. 350/380mm if i remember right..i think i got it within 0.02 difference. Good enough?
    I must say it was sensitive in the tram in Y direction with leveling feets compared to my old B.P.vmc.
    But i will definately check the tram again as it has sa on the floor couple of months now.
    I did some face milling with 50mm mill and the "waves" between then passes were really "good" . Minimal.
    I have also done a test where i find center of a ring with shortest possible holder with dial mounted in
    Then change to longest possible..like 350mm longer
    And the center is within 0.015 0.02 .
  6. #26
    Mar 2008
    288
    normally I prefer .012mm / 300mm (.0005" / 12" inches). If it is out more in X, than Y this would cause what you see.
    Also with scales you cannot check backlash since the scale is trying to hold the axis in position.
    This is NOT the case under a dynamic load when cutting!
    You need to look at the ball-screws. (Procedure attached)
    "_Troubleshooting_Axis_Positioning_Problems-VMC-110518GEW.pdf" (289.0 KB)
  7. #27
    Jul 2020
    38
    Quote Originally Posted by gwood View Post
    Thanks alot for taking your time
    I havent checked the screws more then by feeling them byhand
    And having a 0.002 dial gauge. They feel really nice.
    The finishes it leaves during roughing and finishing are really nice. I cant even feel the slightest errors where it changes direction so focus on the screws has been minimal.
    I have witnessed some sloppy screws on the scales machines and during machining you can easily feel the backlash on circles
    I am thinking of stacking up some calibration gages of 300mm measure first in X with 3d taster. Then measure in Y direction ( first turn taster 90 degreees )
    Im pretty sure the measurement will differ 0.02.
    What would be the cause of this then?
  8. #28
    Mar 2008
    288
    The tests I provide instructions for on the end of the ball-screw take less than 15 minutes;
    spend your time looking for bad thrust bearings; or ball-screws that have lost their preloads.
  9. #29
    Jul 2020
    38
    Work getting in the way of perfecting this old girl.
    I did have a feel on the backlash i would say its in the 0.005mm so imo. Still pretty tight.
    I have confirmed that a dia. 44mm hole is interpolated within 0.005mm
    Dia 170. In 0.015mm
    Dia 300 0.035mm
    I did end up squaring the X and Y from 0.02mm to 0.008 it gave
    Very little error.
    I have confirmed against a square granite that the table dont drop towards X limits.
    I have milled 4 flats 300x300 and the difference in measures across is just the same as the circle..Smaller in Y
    I have done some testing how it repeats positioning and its very very good. Nothing seems to be loose.
    I have tried turning off pitch error compensation in X and Y and it gave nothing.
    My next step is to mount a separate 0.001mm resolution scale on the table with holder from spindle and compare the movements.
    Unless anyone comes up with something more to check
  10. #30
    Jul 2020
    38
    Another thought
    Does anyone know where to access the thermal compensation for Y? The machine is in a enviroment that is abit colder then 20c wondering if that could mess things up?
    But i reckon it should compensate for "float" of spindle heat on the column rather then stroke?
  11. #31
    Mar 2008
    288
    Kwirk, There are two thermocouples; one on the Side of the column near the toolchanger assy., the other inside the spindle carrier down on the inside where the Spindle assembly bolts in.
    The Spindle assy has a 13 digit 25mm high plate riveted on the bolting flange outer diameter 06126xxxAyyyy below the casting; but above the lower sheet metal cover.
    The MSN 70xx-A0x-yyyy
    Does the machine have a spindle heat exchanger and fluid pump.
    What is the MAX programmable spindle speed?
    On the A2100 Service page what release software is loaded? System Software = SYyymmdd Release 2.x, 3.x, 4.x ?
    This info is need to verify the Thermal comp tables.
  12. #32
    Jul 2020
    38
    Thanks for getting back
    The spindle nr is 061264424000
    It is a 8k unit with no chiller. Oil lubricated.
    Software release 4.13
    MV001214
  13. #33
    Mar 2008
    288
    Kwirk,
    Attached: 91204316-001A_EKK_Rel4x_Config.pdf (354.9 KB) Page # 2 & # 5 (Thermal Comp)
    Your Spindle (61264424A 8k STD Torque) or 10K with Spindle Cooler
    Attached: VMB-TB-KT-012a_EKK_ILC_Lube_Setup-Rev_A.pdf (386.3 KB)
    GWood
  14. #34
    Jul 2020
    38
    Kwirk,
    GWood
    Thanks. Cant see anything wrong
    Im thinking off turning the "thermal comp selection" feom ambient to inactive or absolute. Should be safe ?
    And then do a test.
    Control re boot needed?
  15. #35
    Mar 2008
    288
    It your choice; but I would bet it is mechanical alignments, or leveling.
  16. #36
    Jul 2020
    38
    I believe you..just running out of ideas.
    I did now measure with 0.0001" dial and the out of round is
    0.0127 per side so a diameter in X is 284.00m and in Y
    283.9873mm
    The smaller it get the better it is.
    Would a tram error do this ?
    Would tram error result a square to be smaller in one direction too ?
    I will borrow a level and check the machine when i have time for it
  17. #37
    Jul 2020
    38
    For now i adjusted pitch error til the Y axis makes the perfect circle and same size square as X
    It now interpolates a d250mm within 0.005mm.
    Makes square 250x250
    A smaller hole is in same center location as 250.
    When cmm time at work is avaible i can fine adjust other stuff.
    I feel like i did a dirty fix as its probably something
    Mechanical as gwood states.
  18. #38
    Jul 2020
    38
    Update.
    But not any big news but...
    I have been running the machine with my edited pitch error table. It has been ok.
    But machine started slowly developing a high pitch beep in Y axis. Move it little = quiet. Move again high pitch.
    I was able to mask it with some servo tune.
    But the longer the machine ran the worse it got.
    So something was going on.
    I started with easiest and changed the rubber couplinh between screw and motor and its quiet again.
    Seems like it set the motor out of balance.
    Havent done any test cutting as i'm busy atm...
    When i got thw machine i had to change the X axis rubber too as it was much worse..
    I guess i should change Z too..
  19. #39
    Mar 2008
    288
    The 90 Durometer RED Spider Coupling wears out over time (Siemens Drives, model EKK ) and can cause the squealing due to mechanical slop between the motor driving the ball screw and the SCALE
    feedback attached to the table.
    Looseness causing the noise can be from the Ball Screw Thrust Bearing, the Ball Screw Nut Preload, the loss of tension in the X-axis that has and outboard support
    set of Thrust Bearings with a .001" Stretch (Arrow 1000 and up); the motor coupling or the red-spider if applicable.
    There have been posts addressing how to look for ball screw / ball nut looseness.
    Lack of lubrication to the nut will cause looseness and eventually damage. The Model EKK (yr 2000 mechanical design), and EKT (yr 2002 mechanical design);
    did NOT have lubrication line to the ball screw but instead a special oil felt pad lubricator of THK design. You could put grease on the ball groove and slowly feed over it to lubricate it.
    You CANNOT use a full synthetic coolant (metal working fluid) that has no soluble cutting oil in it or you will destroy the ball screw nut and linear bearing trucks!
    Some of the linear bearing trucks had zerk/alemite grease fittings and can be greased with NLGI-#2 Lithium based grease.
Page 2 of 2 12
  1. Pitch Error Compensation
    By crow36 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-09-2022, 11:31 PM
  2. Both-direction pitch error compensation!!!
    By Rukam22 in forum Fanuc
    Last Post: 04-25-2020, 11:01 PM
  3. Error 3094 in compensation data
    By zappa42m in forum SIEMENS -> Sinumerik 840C
    Last Post: 08-10-2009, 06:14 AM
  4. Radius compensation error messages
    By visky in forum LinuxCNC (formerly EMC2)
    Last Post: 05-24-2008, 10:10 PM
  5. Machine pitch error compensation
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2006, 05:52 PM
