588,342 active members*
5,308 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Aug 2005
    578
    Which one actually made the DXF, Photoshop or Illustrator?
    Illustrator does Photoshop does with a plugin I think....
    Bob
  2. #22
    Chris,
    I use photoshop to bring up the contrast and lightly touch up any areas (the shine on your image) that would cause problems tracing.
    I then use Illustrator for converting it to vector.
    Though similar to the trace feature in Corel, Illustrator allows quite a bit more fine tuning of the trace resulting in more precise and/or cleaner trace.
    It is also pretty much the standard in the graphic design industry.
    ~Kevin
  3. #23
    I saved the file as DFX in Illustrator.
    Photoshop was used just to take the glare off of the photo
  4. #24
    Oct 2008
    12
    I must be dumber than I thought. I saved the file to a jump drive and took it to the computer that has bob cad I can not get it to open I don't know if it is just me or what. I am sorry guys I thought I knew what I was doing. Any suggestions?
  5. #25
    BobCad is your domain.
    I know nothing about it!
    ~Kevin
  6. #26
    Apr 2008
    1577
    Quote Originally Posted by ck cues View Post
    Right click the link, Save target as. Make sure it is saving as a DXF file. What version of BC are you using?
  7. #27
    Oct 2008
    12
    Unhappy Thank you
    I would like to thank everyone who helped me get started. Kevin and sbc cycle I would have been lost without you. I got it loaded into bobcad and sized. I was going to cut it and post pics but I found out I am out of .007 endmills. If I can borrow one from another guy I should post pics by tomorrow evening.
    Chris
  8. #28
    Oct 2008
    12
    Quote Originally Posted by SBC Cycle View Post
    I am using bc version 21.
    Chris
Page 2 of 2 12
  1. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  2. Converting PDF file to Mastercam 9.1
    By chop5280 in forum Mastercam
    Last Post: 05-03-2006, 10:50 PM
  3. Converting a File
    By Tazzer in forum ArtCam Pro
    Last Post: 10-30-2005, 11:52 PM
  4. Converting a .max file
    By DAB_Design in forum Uncategorised CAM Discussion
    Last Post: 01-28-2005, 08:00 PM
  5. Converting jpeg. to dfx.file
    By tozlakes in forum Waterjet General Topics
    Last Post: 12-23-2004, 10:40 PM
