588,460 active members*
5,445 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Upgrade of Huanyang vfd
Page 2 of 19 123412
Results 21 to 40 of 378
  1. #21
    ericks Guest
    Re: Upgrade of Huanyang vfd
    Jase....i am glad you got that sorted. Yes you should be able to change the display to indicate hertz....
  2. #22
    Jun 2017
    238
    Quote Originally Posted by potts43 View Post
    Ericks you are a star that worked!!!
    If I press the Hand on button the supply doesn't run until I turn the pot. It then goes from 0hz to 400hz. A Brilliant start.
    Is it possible to replace it showing hz to rpm?
    I have wired my mach3 breakout board to terminals 18 and 20 of P.S. and this turns the spindle on and off from mach3. However it appears to have it running at maximum rpm and as the power supply has to be in auto start mode the knob doesn't work. The software up and down buttons don't change the spindles speed.
    Obviously doing something wrong here. Any ideas? Is it possible for Mach3 to tell the spindle what speed to run at and/or be able to vary the spindle speed from mach3?
    And hopefully last.....
    I bought an external box with an emergency stop button and rpm pot on it.
    I've tried wiring it to the P.S. but they don't appear to work. Once again Danfoss provided some instructions but they didn't work so if you can help me I'm ready to try your ideas.
    Thanks Jase
    Sent from my SM-G935F using Tapatalk
    The wiring I was told....
    Yellow 55
    Black 53
    White 50
    Black & mach3 cable 12
    Mach3 18
    Red 27
  3. #23
    Jun 2017
    238
    Quote Originally Posted by ericks View Post
    I would prefer rpm rather than the default Hz.
  4. #24
    15362
    To control the speed you need to have a ( PWM signal ) output a 0-10v from your Breakout Board to the VFD
    The right side of the display shows the unit of the selected parameter. This can be either Hz, A, V, kW, HP, %, s or RPM
    You can change this to what ever you want it to be
    Because you have a quality VFD Drive you can use the minimum that your spindle can run at=100
    3-02=100
    3-03=400
    4-12=100
    4-14-400
    Mactec54
  5. #25
    Jun 2017
    238
    3-02=100
    3-03=400
    4-12=100
    4-14-400
    Mac thanks for the reply. Do you know which terminals that would be connected for the 0-10v?
    I can't seem to find a place to change the output to rpm. I'll study the manual again.
  6. #26
    Jun 2017
    238
    This is my bob.
  7. #27
    Jun 2017
    238
    This is my power terminals. I believe the two green lined are the 0-10v on the bob. Which ones on the power supply should I connect them to?
  8. #28
    15362
    Terminals 53 and 55 for the 0-10v connection
    Mactec54
  9. #29
    Jun 2017
    238
    Brilliant I'll try that. Do I need to set anything up in mach3 for this?
  10. #30
    15362
    Yes you will
    Mactec54
  11. #31
    Jun 2017
    238
    Can anyone put me out of my misery?
    Tried all morning and can't solve it....
    On the old Chinese inverter I could set the speed with the pot then run the gcode and it would cut at that speed. Every time I do the same thing it runs at the spindles maximum.
    I'm pressing the Hand and rotating the pot to the required speed. Then press auto on. Then run the gcode but it spins up to 24k.
    Any ideas?
  12. #32
    ericks Guest
    Any ideas?
    I would be able to help you, sorry i didn't reply before....been flat out, we just moved and busy renovating. Not sure when i will be able to though, i already got a vsd and same bob as yours ready to set up so i can give you the connections and parameters. Hopefully i will get some spare time next couple of days
  13. #33
    Jun 2017
    238
    Brilliant thanks!
  14. #34
    Jun 2017
    238
    Tried wiring the Bob to the inverter today but as I never built the cnc machine I'm lost when it comes to the configuration in mach3. I can get it to turn the spindle on and off but if I run gcode it runs at 24k rpm and can't alter it. How do I workout the pins etc for the spindle motor?
  15. #35
    15362
    Here is a setup that was done for a lathe, this will show you what settings you need to do in Mach3 yours will use different numbers to this and you won't have the spindle feed back
    There are a lot of you tube videos also, and information on the Mach forum Machsupport Forum - Index
    Mactec54
  16. #36
    Jun 2017
    238
    No setup here mac?
  17. #37
    Jun 2017
    238
    No setup here mac?
    Mac been trying to get this drive to allow spindle speed to function from both an external box pot and from mach3 without success. I keep reading the manual to see if like my old drive there is a setting where you tell it to take commands from an external source but cannot locate it. Can you help?
  18. #38
    Jun 2017
    238
    It came though. I'll start reading. Quick question. What do the numbers in the pin box refer to so I know what numbers I need.
  19. #39
    Jun 2017
    238
    I think my issue may be with my Bob. I wired it like this. The left hand side Estop is p10 and gnd but when the connection is made nothing happens. I wired the right hand side as you advised but nothing functions. I found this manual and copied the pins (my setup didn't come with one) so pwm is on p1. However nothing happens. The relay on off to the spindle does work but runs at max.
    Am I doing something wrong here or could the Bob be faulty?
    Thanks.
    Tapatalk Cloud - Downlaoad File BOB.pdf
  20. #40
    15362
    Thanks.
    You have to set the correct pins in Mach to match the breakout board for the 0-10v output
    In motor Tuning have you set the spindle settings
    Mactec54
Page 2 of 19 123412
  1. Huanyang VFD
    By lt00273 in forum Chinese Machines
    Last Post: 09-13-2017, 04:55 AM
  2. Huanyang VFD
    By lt00273 in forum Spindles / VFD
    Last Post: 09-07-2017, 06:10 PM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
