![Quote](images/misc/quote_icon.png)
Originally Posted by
Goemon
That's all true although those old Bridgeport 1hp motors are considerably more powerful (in terms of material removal) than your typical 5hp 18,000 or 24,000 rpm spindle. You would need even higher HP to reach 1 hp at 1000 or 1500 rpm.
You only have to look at the Datron spindle choices to see that you are correct about how little power and torque is really needed or even recommended for milling aluminum (or even steel) at high speeds with smaller end mills. I didn't choose my spindle for the high HP. I chose it because it was a good deal on a spindle with other features I wanted (and a good brand). If I was in a position to buy exactly what I wanted, I would have chosen one with lower HP and lower top speed.
The reality is that at the speeds I'll be using my spindle, it is really a 3-5hp unit. I'll never run it at top speed because I don't want to blow the VFD and I don't need the high rpm. I think I'm safe running one spindle like that. For two or three at that power, I would want additional breakers for each.
