587,940 active members*
3,368 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > Trying to cut 1/2 acrylite cast acrylic. Have tried everythin
Page 2 of 2 12
Results 21 to 29 of 29
  1. #21
    Feb 2016
    381
    Re: Trying to cut 1/2 acrylite cast acrylic. Have tried everythin
    Quote Originally Posted by launchpad View Post
    Louis, what spindle are you using?
    Sent from my SGH-I337M using Tapatalk
    My normal spindle for cutting acrylic is a 500w DC variable 0-5000rpm I also use a 2.2kw VFD water cooled but seldom use for acrylic if I do up feeds as required.
  2. #22
    Jun 2014
    777
    Well you have some really varied replies here. I would suggest you start at 8k. As mentioned be aware of what the chips are doing. They should be individual curls of acrylic, if they begin to fuse together, increase feed.
    You could also try using water to cool.
  3. #23
    May 2012
    114
    well folks. I guess I tried everything BUT having my spindle turning the bit in the proper direction... I guess at some point along the line of hooking everything up and testing and retesting during machine assembly, I got two of the wires on the vfd to spindle backwards. DOH. So when I was giving my machine a M3 command I was in reality getting a M4. Ha ha. Apparently that approach is much more forgiving in wood than it is in acrylic. <facepalm>
    Attachment 319282
    The wires to the right are what were switched. 1 got swapped with 3 somehow during my bench testing and putting it on the machine itself.
    Attachment 319284
    Cut comparison. Apparently when the bit goes backwards all you get is broken bits and melty plastic. Aha
    Actually getting feathery chips now. Instead of molten BB's
    Attachment 319288
    Shocked that the old way was even able to cut anything out at all.
    Attachment 319290
    First acrylic part hot off the press!!
    Attachment 319292
    Attachment 319294
    Attachment 319296
    Bottom part of my dust shoe complete!! Now I have to venture an hour away to go get more acrylic to finish the job. At least I know where to find it cheap. Hah
    Moral of this story is make sure your spindle is spinning the proper way kiddies.
  4. #24
    Apr 2004
    475
    LOL. The O flute would really work against you in that case. Amazed it worked for even 5 seconds. Glad you found the problem.
    Sent from my ASUS_Z00TD using Tapatalk
  5. #25
    Aug 2009
    655
    So spill the beans, what feed and speed....
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  6. #26
    May 2012
    114
    63-520 Onsrud "O" flute (3/16" bit"
    16k rpms
    64 ipm
    .1 depth of cut
    conventional cuts all the way
    30 degree ramp in
    So smooth. I am so happy
  7. #27
    Jun 2014
    777
    Quote Originally Posted by ericclinedinst View Post
    Attachment 319282
    Attachment 319284
    Attachment 319288
    Attachment 319290
    Attachment 319292
    Attachment 319294
    Attachment 319296
    Lol it happens.. i did this for a couple of hours when i set up my latest machine wondering why all i could make was smoke.
  8. #28
    Dec 2015
    36
    Eric, that looks great. What have your results been when using the acrylic for this project? I made a dust shield almost identical to the one that you have and found that the acrylic kept braking at the joint that tightens it to the spindle. I wound up using clear polycarbonate in 1/2" and have had zero issues since.
  9. #29
    Feb 2016
    381
    Tip with acrylic is Dichloromethane it welds acrylic strong as the original solid mateial and with good joints they disappear making it one piece, extremely quick and strong I even use to make T_slot brackets for 50kg hold downs and the acrylic will break at other places before the joint moves. This is 4 layers of 5mm acrylic welded in the horizontal and welded the joint is just as strong as the material if not stronger, the clamp has had months of abuse and high tension and the only one of 10 to fail but not on the joint.
Page 2 of 2 12
  1. Anyone machined cast acrylic sheet?
    By kvom in forum Novakon
    Last Post: 03-29-2014, 01:21 AM
  2. How large air compressor to use for cast acrylic?
    By Metalmidget in forum Tormach Personal CNC Mill
    Last Post: 09-06-2010, 08:04 PM
  3. Optimal Carbide Insert for Cast Acrylic
    By bdphillips03 in forum Glass, Plastic and Stone
    Last Post: 01-27-2009, 04:57 PM
  4. Cutting 2" cast acrylic
    By routski in forum Material Machining Solutions
    Last Post: 01-11-2008, 09:44 AM
