603,923 active members*
3,873 visitors online*
Results 21 to 23 of 23
Threaded View
stewi Open source P&P revolver... 12-02-2011, 03:05 PM
stewi Front and rear of the... 12-02-2011, 03:59 PM
Nails Facinating.....I can see how... 12-02-2011, 05:42 PM
stewi Yes, you are on the right... 12-02-2011, 07:19 PM
stewi In my ACAD design, I... 12-02-2011, 07:58 PM
dandumit What a pity that you don't... 12-03-2011, 06:45 PM
stewi I will not totally erase that... 12-03-2011, 06:58 PM
dandumit Like you have presented it... 12-05-2011, 08:38 PM
stewi Getting started could be a... 12-06-2011, 04:08 PM
Nails I don't know whether to thank... 12-31-2011, 08:30 PM
stewi Looking at the wire frame... 01-01-2012, 12:03 AM
gattuso Re: Open source P&P revolver... 05-15-2019, 03:01 AM
    Jul 2011
    Open source P&P revolver head
    I like to share some insights on a multiple nozzle revolver head.
    This is just a drawing and I have no intention to build this. However, I will assist whoever wants to build one.
    Starting with a 5 mm thick plate, which is covered with another 1 mm plate I attached a disc stepper to it.
    At the front side I have a circular track with two openings. At the lower opening the head segment will exit here for Z-motion, to the right the head segment will engage with a stepper motor for nozzle rotation.
    The plate is milled out with two paths, one for vacuum (air/kiss) in the lower pick position, one larger one for the rest of the nozzles.
    I've designed an eight nozzle head, but any other number is feasible.
    The lower hole for vacuum has a 3 mm opening, all other 2mm.
    At the end of the path, I will attach vacuum generators. Likely one for pick and place and 3 for the other.
    The wheel hub is two parted. The longer one is attached to the motor shaft and the "star wheel", the shorter containing 8 3mm tubing will slightly press on the plate via spring tension.
    I've tapered all holes in the Nylon or Teflon wheel, in order to assure the vacuum will not drop, when the wheel turns.
    Attached Thumbnails Attached Thumbnails revolve1.jpg   revolve2.jpg   revolve3.jpg   revolve4.jpg
  1. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  2. open source 3d scanner
    By zhanx in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 11-11-2011, 01:28 PM
  3. OPEN SOURCE BLUEPRINTS?
    By denis6902 in forum Open Source CNC Machine Designs
    Last Post: 03-05-2010, 02:04 PM
  4. Open Source Cad Cam
    By kch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2007, 12:51 AM
  5. What's in work at the open source
    By pminmo in forum Open Source Controller Boards
    Last Post: 02-13-2005, 08:55 PM
