587,999 active members*
1,840 visitors online*
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    May 2004
    290
  2. #22
    Sep 2006
    881
    hey now thats not a bad idea, the dryer looking hose.. light, cheap, and can get more later... hmmm seems easier than the slinky idea....
    Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino.
  3. #23
    May 2004
    290
    Quote Originally Posted by project5k View Post
  4. #24
    Feb 2020
    Re: protecting/cleaning lead screw
  5. #25
    Nov 2005
    222
    McMaster has a few options. Here is one.
    https://www.mcmaster.com/bellows/bel...flange-ends-9/
  6. #26
    May 2005
    3920
    You are right to be concerned about dust. One of the best things you can do is maintain the machine regularly. That is clean and lubricate the screw. Sadly the rotating screws seldom fling off the dust, larger chips maybe but if you have lube on the screw dust will stick.
    As for buying screws and nuts, Buy nuts with wipers. Wipers are the final defense in keeping out crude.
    Bellows can be a very good solution for shorter screws. However you loose travel due to the collapsed length. This means ever longer screws to maintain travel. At some point you may want to consider other methods.
    In some cases covers made from sheets of flexible materials like shower curtains, rubber sheet , canvas and various plastics have been used. The fact is this was a common approach on bridgeport mills for years to protect the plain ways and the mechanics under the metal slides. There are various ways to do this including having the covers roll over the edges.
    If you are real handy with sheet metal sliding metal covers are nice.
    If at all possible position screws such that they are out of the direct path of falling chips. With careful design you may not need additional protection.
Page 2 of 2 12
  1. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  2. How do you mount a lead screw/lead nut?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 11:10 PM
  3. Belt vrs. Ball Screw vrs. Lead Screw
    By stevesplanes in forum Linear and Rotary Motion
    Last Post: 01-09-2006, 06:23 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. Ball Screw or Lead Screw? Which is Better?
    By ljoe1969 in forum DIY CNC Router Table Machines
    Last Post: 07-28-2004, 02:49 PM
