588,386 active members*
5,176 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Sep 2014
    128
    Re: Anyone has SH-G350D cutter?
    no, should be held in mechanically, eg a screw / collet arrangement
  2. #22
    Jan 2015
    62
    Here's what mirror looks like. Just to confirm, it's not supposed to look like that, right?
    I could be wrong, but it looks like a piece of polished metal which corroded... WTF?
  3. #23
    Jan 2015
    23
    Uhhmmm.... that mirror doesn't look the way I guess a co2 mirror should.
    This is the picture of a brand new mirror, found on the web.
    Attachment 269446
    I just received my 350 but still not able to put it at work nor test it. After this, first thing will be checking the mirrors...
  4. #24
    Jan 2015
    62
    Quote Originally Posted by itmaxx View Post
    Yeah let me know what you discover! I'm pretty sure it's corroded over time as it was probably in storage for a year or so. There was some water in the system too, that didn't help...
    I was just researching about which mirror to get. There are various types (i.e. Silicone (Si), MO, etc.) some are gold plated, some are not, but I'm not sure, there's very little description... They are quite pricey about $30 per mirror. But it also looks like one can make mirror almost for free with a HDD platter . I'm going to try that, already ordered 25mm diamond tipped hole saw from Amazon. They say it's for glass, but I'm hoping it will be able to cut metal too...
    BTW it's 25mm diameter mirror if anyone curious.
  5. #25
    Jan 2015
    62
    Small update. I started writing about my experience on my website. You are welcome to follow along, I'm hoping I don't procrastinate too much and keep updating it. Unboxing video is up.
  6. #26
    Aug 2014
    111
    SI mirrors is OK, dont buy cheap K9
    Si Mirror:*Silicon Glass Gold coated, great reflective index, not good for anything 80 watts or over (not too hot on 60 watts either)
    Mo Mirror:*​Molybdenum, very tough but the lowest reflective index, great if you miss cleaning or have a habit of dropping mirrors or if you have over 80 watt sources.
    Cu Mirror:*Copper, Below gold Si for reflective index but tough and better index than Mo
    K9 Mirror:*Close to worthless gold coated glass (likely from re-melted milk bottles), anything much over 35 watts and a spec of dust and they break. Designed for the "Hobby" series K40 lasers (the $500 ebay junk)
  7. #27
    Jan 2015
    62
    Quote Originally Posted by miketola View Post
    Thanks! Great info! I ordered Si mirrors.
Page 2 of 2 12
  1. Inte200 MK4 Matrix control - Milling cutter EIA cutter radiusr compensation G41
    By Stavros Flatly in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-19-2013, 02:48 AM
  2. Any information about Shenhui Laser DC-G350D?
    By supertronic in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-18-2011, 10:08 AM
  3. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  4. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 10:15 PM
