588,073 active members*
4,909 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > ExcelCut 4 Axis Wing Cutter with Source Code
Page 2 of 2 12
Results 21 to 40 of 40
  1. #21
    May 2004
    10
    I finally got a hold of arman, so I'm good to go.
    Bart
    Regards,
    Bart
  2. #22
    Nov 2010
    excelcut still available?
    Cheers arman, hi everybody!
    just came across the excelcut project - very interesting.
    I tried to locate it on the www to have a closer look but
    it seems like the links don't work (netmyne...).
    Is there any other chance to get a closer look to the
    package?
    Thanks and best regards
    Dolphi
  3. #23
    Apr 2011
    Is there an alternative download site for this software. The original site seems to be down.
    Or does someone have a copy of the latest (4.2 version ?) they could send me? The software is free for personal use.
    Thanks!
  4. #24
    Mar 2011
    I am also interested
    Did you ever found how to get a hold of a copy?
    Please post here so everyone can download.
    Rony
  5. #25
    Apr 2011
    Sorry, no rony. I also wrote to arman who wrote the software but never received a reply back. Surely someone must have a copy!
  6. #26
    Jun 2009
    I've included a copy of Excelcut.
    Source: DIY Hotwire CNC - RC Groups
    Vincent
    Attached Files Attached Files
  7. #27
    Apr 2011
    Thanks, I actually posted that one in your reference myself -- it is an early version which I had subsequently found cached on the I"nternet Wayback Machine".
    I wonder if we can get a newer version from someone.
    I also wonder if anyone has the skills to get it running on the (free) Open Office Calc rather than Microsoft Excel. That would open it up to everyone.
  8. #28
    Jun 2009
    I've got problems getting good G-code from Profili Pro 2.30a.
    It just has too many bugs, and some simple things just can't be done.
    I'm writing a new Excel sheet which exports G-code.
  9. #29
    Apr 2011
    Pro-per, good for you! I've had similar problems with Foamworks and a few others in both G-code and .DAT output files from DXF
    I was also hoping that Excelcut might furnish a means of customizing the translation by understanding the Excel source code.
    I run Linux however, and while I have a couple old computers with Win 98 and XP on them, my newest Excel version is 2000. Excelcut was developed on Excel 2003.
    I really wish this program could be adapted to Open Office Calc -- which would open it up to most operating systems, including both Win and Linux, instead of being tied to specific versions of Excel, etc.
    Anyway, good luck!
  10. #30
    May 2005
    Thanks for posting the file, prop-er.
    Much appreciated.
  11. #31
    Jul 2011
    37
    I know this is a bit off, has anyone attempted
    this?
    I tried to look at the code which is Visual Basic.
    Unfortunately, the code is password protected
    so first I need the password to compare with
    calc scripting paradigms.
    The only way to port it is to first have access
    to the code, which would then need to be ported
    to calc.
    So, if you can get me the password, I'll be happy
    to see what porting it will entail.
    Quote Originally Posted by High Seas View Post
    arman - Greetings.
    Porting the ExcelCut to Open Office would be real nice! Aa great combo - 2 freebie programs!
    Is there a way to test/check a file without having the controllers attached to the pc? I'd like to do that to make sure all is well before taking the file out to the "shop." Maybe some trick to fool the software into not looking for the controller?
    :cheers: Jim
  12. #32
    Jul 2008
    14
    EXcelCam access to Visual Basic code?
    This is a repeat of a prior post, but does anyone have access to the password for the VB in ExcelCAM? The program seems to do most of what I need but I would like to look at the VB to see what's going on and add features at some time.
  13. #33
    Mar 2012
    Self made wing cutting software
    Hi all,
    I have tried to make my own wing cutting software. Believe me it's a great masochism
    It works good, but is not too user friendly. Work on DOS and source is on pascal.
    But if somebody want to see source code or use it for cutting, let me know.
  14. #34
    Jun 2009
    There's a new great 4 axis foam cutting program called Schnapps. Does everything, and is free:
    SchnApps40
    http://code.google.com/p/schnapps/
    Styroschneiden nach Konzept Hans23 mit SchnApps :-)
  15. #35
    Mar 2012
    There are the same functions but this 'SchnApps40' has very nice interface. I've been too lazy to do that 10y ago.
  16. #36
    Jul 2011
    37
    Blue Foam is written in java
    I got an error page on the schnapps code links
    and the project did not come up when I searched
    the projects at code.google.com.
    However, when doing a search for wire foam
    the blue foam project came up.
    Here is the link.
    http://code.google.com/p/blue-foam-cnc/
  17. #37
    Jul 2011
    37
    Thumbs up
    (chair)
    Upon further review, I find that there are no downloads for
    the bluefoam project. (nuts)
    Sorry about that.
    Quote Originally Posted by satovey View Post
    Here is the link.
    blue-foam-cnc - Desktop-side software for the Olin Principles of Engineering Styrofoam CNC Machine - Google Project Hosting
  18. #38
    Mar 2012
    Quote Originally Posted by prop-er View Post
    There's a new great 4 axis foam cutting program called Schnapps. Does everything, and is free:....
    I mean if somebody curios to know source and principle of operation of that kind software.
    It's an very old my project.
  19. #39
    Jul 2011
    37
    Quote Originally Posted by Pandurko View Post
    Thanks for the posting the code.
    I'm looking at this stuff from a purely CNC perspective and thinking about porting LinuxCNC to Windows. So I'm studying up.
  20. #40
    Mar 2018
    15
    Re: ExcelCut 4 Axis Wing Cutter with Source Code
    Vincent
    Please ExcelCut last update version ? Other Excel files for CNC, cutting and VB apps ? thank you.
Page 2 of 2 12
  1. 4 Axis CNC - MS Excel Source code (VBA)
    By arman in forum Visual Basic
    Last Post: 03-06-2018, 01:37 AM
  2. Wing cutter in the Netherlands
    By Witsenburg in forum CNC Wire Foam Cutter Machines
    Last Post: 10-16-2011, 01:11 AM
  3. Wing cutting and 4 axis g-code
    By THend in forum CNC Wire Foam Cutter Machines
    Last Post: 07-08-2009, 11:24 AM
  4. G-Code viewing source code
    By Hussam in forum Visual Basic
    Last Post: 03-15-2009, 06:15 PM
  5. CNC Foam cutter for RC plan wing
    By jc de campo in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2008, 01:21 PM
