588,348 active members*
6,033 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > New Microsoft Vista Will Our "STUFF" work?
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Feb 2006
    1260
    I had issues trying to use Vista. I'm not saying it can't be done just that I had problems with it. I would recomend the use of XP Pro.
    I even went so far as to remove the Hard drive from the Vista system I had purchased. Replaced it with a new clean drive, formatted & installed XP Pro. Then I found I had issues with getting drivers to work with the integrated motherboard. that came in the Vista Computer.
    So if you go the XP pro route I'd either buy it that way or build it from the ground up using XP compatible hardware.
    Just my 2c.
    If it works.....Don't fix it!
  2. #22
    Oct 2007
    111
    That's what I wondered. I guess I'll buy a latel model machine with XP and do a clean install and save a few a bucks as well..........but darn it, I won't have that new computer smell..
  3. #23
    I ended up going with XP instead of Vista... So I can't help with anymore of the XP vs. Vista... since I am running XP. I heard from Artsoft (MACH3) that Vista could and should work, but XP is tried and proven and has all nec. patches taken care of for the most part so there are few glitches.
Page 2 of 2 12
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum Community Club House
    Last Post: 05-18-2008, 03:53 PM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
