603,942 active members*
2,685 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Sep 2007
    52
    Some guitars made with my machine
    I thought I would post here a few guitars I made using my new build FLA machine...I posted the machine on here elsewhere and was asked about what I made and did not want to put these there...Anyway, here they are...The purple one also has binding on the top edge to break off the quilted maple top from the back, and tiger maple neck...They are unrubbed lacquer finish....
    There is also a Stratish type that is unfinished because my son has a sign business and does lettering and airbrush work so he wanted to paint it..Will post that when it is done...
    Nov 2014
    708
    Re: Some guitars made with my machine
    Those look really nice, Joe. Did you draw them or use ready made files? How about the necks - did you cut these or buy them ready to use? I haven't decided yet which path to take on both the body and neck whenever I get around to doing an electric.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Sep 2007
    52
    David,
    The files were purchased..I will not say anything good or bad about them, but you can't put them in your machine and have a guitar come out...It took some work to get to this stage..I did cut the neck also..It is done in Vectric V-Carve pro....The way I did the neck was to put locating holes on the centerline of the drawing, and then toolpath it...After you machine the top, you would then flip it over on your locating holes, and machine the back..This is where sometimes you get into trouble, and whast I mean about the files needing work....I will post some pics here and I think it will show the locating pegs on the neck...Look at the first picture, and it will show one of the locating holes at the bottom of the neck..Then look at the others when it is flipped over and you can see the locating peg in the hole...I hope I explained it well …..I don't know why the pictures are sideways, I can't seem to change them.
    Jul 2018
    6841
    Hi Joerom - I made a couple of necks for a friend and registering the part in the turnover is not easy!! A rotary is on the list for that sort of thing. Peter
    https://www.facebook.com/ScootCNC/vi...1303486179863/ a practice neck
    Sep 2007
    52
    Peter,
    I put the rotary on my machine for that purpose but have not used it yet...If you go to Fineline Automation forum you will see it if you have not already.....
    Nov 2014
    708
    Quote Originally Posted by joerom View Post
    David,
    Thanks, Joe. That's how I envisioned doing it but have yet to watch any videos or check into it because I'm not ready.
    On the photo rotation, here are some photo posting tips if you’re taking photos with your phone or iPad – the best way for proper orientation is to shoot landscape (widescreen). Rotate your phone or iPad CCW for proper orientation. If you want your photos to be portrait then open the photo in a viewer on your computer, rotate it to the orientation you want, then save it in that orientation. It will be correct when you upload it to the servers here. If you’re shooting video please shoot widescreen like our monitors, not portrait.
    David
    David
    Romans 3:23
    1347
    Its always nice to see some finished projects and it does encourage people to persevere with getting their machines running.I've never had to work with guitar components,but I have some experience with second operations on one or two different machines.They key was to use a suitable fixture at a known position and that probably won't be easy to do with Vcarve until you have an .stl file of the fixture.Presumably the files for the components were supplied in .step,.igs or .stl format.and if you can subtract this shape from a solid block in some other program,you should be able to generate a fixture with the mating surface for you parts.The easy way to make it work isn't to toil through the process of offsetting all the surfaces and trimming/joining them.Instead just lie to your tool library about the actual size of the ball end cutter you use.If for example you have a 6mm tool-tell the tool library its actually 5.8mm (best to give it a description that labels it a clearance cutting tool)o r so and the toolpath will have a bit of clearance for the machining cusps.
    Sep 2007
    52
    Like I said, you can't put the files in and expect a guitar to come out..Once you know what is what with the files, it is a simple matter to cut a neck or body...The only fixture I need is a 1/4" dowel...
    May 2006
    807
    Good to see others making things like guitars.......
    Do you need some dwg or 3D guitar files to machine?
    I have lots of work....
    Been doing this too long
    Sep 2007
    52
    bostosh, thanks for the offer, but health issues are forcing me to sell the machine..........
    Nov 2014
    708
    Quote Originally Posted by bostosh View Post
    Are you offering files?
    David
    David
    Romans 3:23
    Looks beautiful and special.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Sep 2007
    52
    This will be my last guitar because I have the machine up for sale...It is a one piece quilted maple Strat type that has just the first few coats of lacquer on it...Hoping to finish it in the next couple of weeks.....Attachment 445240Attachment 445242Click image for larger version.
    Nov 2014
    708
    Gorgeous piece of wood! I'm sure the guitar is going to be a fine one, too. Are you replacing your CNC? With what, if so?
    David
    David
    Romans 3:23
    Sep 2007
    52
    David,
    My health has been going downhill and I just do not want to do this anymore...The machine is only a few months old....
    Joe
    May 2006
    807
    Why not complete this build ? put it together ?
    Sep 2007
    52
    I am finishing it..I just do not want to make any more..That is why the machine is for sale......
    Apr 2014
    432
    It does get like that , I have lost interest in some things and moved on to others just like a chapter in a book I like a new one every now and then .I see the enthusiasm in young people more now than I did years ago it's a drive thing for me .
    Sep 2007
    52
    It is almost done now...I still need to do the neck regulating and string it...It is a mahogany neck....Click image for larger version.
Page 1 of 2 12
  1. cnc machine for guitars question
    By moshe_dol in forum Musical Instrument Design and Construction
    Last Post: 04-03-2015, 04:57 AM
  2. New CNC (for guitars) made by Carl Bruce
    By mykaguitars in forum Commercial CNC Wood Routers
    Last Post: 03-30-2015, 04:32 PM
  3. CNC for guitars
    By seansear in forum Musical Instrument Design and Construction
    Last Post: 11-09-2012, 06:15 PM
  4. Suggestions on how to build cnc machine for guitars
    By dinkyguitar in forum DIY CNC Router Table Machines
    Last Post: 02-14-2012, 12:04 AM
  5. CNC Guitars
    By Johnny501 in forum Musical Instrument Design and Construction
    Last Post: 01-16-2012, 04:18 AM
