587,611 active members*
4,324 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD HY 2.2kw 220v wiring to UB1 Controller Help
Results 21 to 23 of 23
Threaded View
    Mar 2020
    60
    Lightbulb VFD HY 2.2kw 220v wiring to UB1 Controller Help
    Hello, all
    Need some help to setup VFD to UC300ETH-UB1.
    Read both manual for UB1 and VFD HY. not much on how to setup wiring.. Most of the information i got from reference on YouTube.
    On my diagram hive following wiring set, except the last wire (AH1), which im not sure where it go.
    On the VFD pin 1,2 are jump for external connection.
    From VFD DCM+FOR connected to UB1 on ON/CM1 relay
    The other configuration came up with:
    AL1---> VFD---> ACM
    AO1--> VFD---> AL
    AH1--> VFD---> not sure
    If anyone can help me connect this right way., So i don't end up doing damageto VFD or UB1.
    Appreciate all the help i can get...
    And to everyone be safe out there.
  1. 220v vfd wiring
    By Chmexdf5633 in forum Spindles / VFD
    Last Post: 03-16-2020, 09:44 PM
  2. Wiring 3P 380v or 1P 220v
    By jwilcott in forum Chinese Machines
    Last Post: 11-18-2016, 09:57 PM
  3. Wiring for Huanyang 220V 2.2kw VFD...NEED HELP PLEASE!
    By justindewoody in forum Spindles / VFD
    Last Post: 03-02-2016, 09:00 PM
  4. Replies: 8
    Last Post: 12-21-2014, 01:49 PM
  5. VFD Wiring from 220v Converter
    By TheProCreator in forum CNC Machine Related Electronics
    Last Post: 09-01-2010, 10:42 PM
