603,855 active members*
4,044 visitors online*
Page 2 of 3 123
Results 21 to 40 of 49
  1. #21
    Aug 2008
    21
    Hello Kirk,
    I worked for CR 8 years. I am software developer but I have also contacts with people
    are servicing these machines and providing consumables. I have asked a price list for consumables. I'll send this to you as received.
    Regards,
    Fabrizio.
  2. #22
    Mar 2009
    WinCam on WInXp
    To install the software in WinXP I simply setup a computer with a Virtual Machine running Windows 98, works well on all our stations.
  3. #23
    Mar 2008
    13
    Quote Originally Posted by FabrizioIT View Post
    Hello Kirk,
    Regards,
    Fabrizio.
    Hi Fabrizio.
    Much appreciated.
    Kirk
  4. #24
    Mar 2009
    Hi guys
    Im new here
    I need a copy of winCAM I have the hardware key but i lost my installation CDs,
    and my old PC is no longer useable.
    I am using a CR electronics plasma.
    can anyone help?
    regards
    Lars
  5. #25
    Mar 2009
    If its the flanges I think your talking about if you need Raw products or if we can provide you with anything check out our temp website:
    http://www.palmerengg-int.350.com/
    Cheers.
    PJ
  6. #26
    Aug 2008
    21
    Hello Lars,
    yes I can help you.
    Please let me know the serial number you see on your dongle key.
    Fabrizio.
  7. #27
    Mar 2008
    13
    Quote Originally Posted by parasj View Post
    Cheers.
    PJ
    Hi PJ.
    Cheers for the link.
    Had a look round your website but we do pretty much everything in-house....
    Kirk
  8. #28
    Mar 2008
    13
    Smile
    We have had one of our plasmas running since wednesday.
    I am very pleased with the results.
    I have just got to find the best way in getting rid of dross/slag....Would a barrell with stones suffice?
    Soon we will be making around 800 flanges a day so might need a decent size barrelling machine!?
    We managed to get around 2500 pierces before had to change consumables which i thought was quite good...These were with genuine hypertherm consumables.
    I had some thermacut consumable samples(non genuine hypertherm) delevered and tried these, but unfortunately they only managed around 20 pierces! Shame really as their prices are really keen.
    http://thermacut.co.uk/
    Kirk
  9. #29
    Jan 2008
    2247
    The Hypertherm HD3070's can cut the materials you are cutting ...virtually dross free. I would suggest having someone that is familiar with those systems (Esprit Automation would be a good choice as they have been working with Hypertherm products for many years) check them out. The HD3070 is a first generation HyDefinition plasma...and if one of them has the torch upgrade....which puts Hypertherm's newest HPR torch on these systems....you should have cut quality that is very close to laser capability.....and consumable parts should last approximately a full shift.
    Do you have the Hypertherm operators manual? If not it can be downloaded from the Hypertherm website......follow the settings for gas pressures, flows, arc voltage, current, consumable part numbers, pierce height and cut speed exactly as outlined in the manual....and you will get excellent quality. I would suggest using the 70 Amp 0xygen cutting process on the materials you are cutting. Use genuine Hypertherm consumables....the aftermarket parts use a 1 piece conventional nozzle design, while the Hypertherm is a 2 piece vented nozzle.....which gives high energy density combined with long life.
    Jim Colt, Hypertherm
  10. #30
    Mar 2008
    13
    Thanks for the advice Jim.
    We do have the upgraded hypertherm torch (HPR130.)Which we was using last week.
    The outline of the flanges are fine....Its the bolt holes that seem to be worse affected with dross.
    We have got a hypertherm manual,and i think we have done all the settings by the book....Will double check monday morning.
    A rep from plascom is coming round next week,so will see if he can improve things....
    Kirk
  11. #31
    Mar 2008
    13
    Forgot to ask Jim....How many pierces/how long is a full shift?
    "and consumable parts should last approximately a full shift".
  12. #32
    Mar 2011
    i need help for my client
    Hello Lars,
    yes I can help you.
    Fabrizio.
    hello fabrizio,
    i need help for my client.
    he uses a old version of the plasma cr . It is the v2.4 but it is installed on PC dos system.
    he tried to install it on Windows98 with the original instal, but the software doesn't work
    the old install works on dos.. i don't understand why ??
    my client would like use another soft like LANTEK . I can not read the code to drive the plasma table.
    the soft writes files like *.tot and *.opt
    can you help me...
    i would like to know the file format and the transfert protocol if it is possible .
    Great thanks and best regards.
  13. #33
    Aug 2008
    21
    CR electronic plasma software
    Hello,
    I think your customer use a version of program called Plasma II ver plot 2.40;
    this is a dos based program that runs even under Windows 98.
    The output file of this program to drive plasma plotter machines are binary files, not like normal text files.
    I can offer to you various solutions for your customer, even interfacing the CR electronic plasma machine with the current Cad-cam system the customer is using.
    Please, feel free to contact me at [email protected]
    I'll show you the best solution in details.
    Kind regards,
    Fabrizio.
    Quote Originally Posted by tglantek View Post
    hello fabrizio,
    can you help me...
  14. #34
    Sep 2011
    Winplasma - Wincam software CR electronic plasma
    Hello,
    I have a CR Electronic machine with HD3070.
    We used computer with Winplasma/Wincam software but now it is fault!
    We have the CD but we can't install the program in a new computer.
    Is there someone cna help?
    Regards,
    Marco.
  15. #35
    Aug 2008
    21
    Quote Originally Posted by Marco_68 View Post
    Hello,
    Regards,
    Marco.
    Hello Marco,
    the original program Winplasma (last versions called Wincam) for CR electronic machines use a protection key to give access.
    The first release used an internal key, while the last versions swapped
    to an external key.
    If this key is not working you can't have access to the program.
    I can investigate further if you give me more info about this, and may be
    I can find the problem.
    I created anyway some tools to help customers to change software
    or use other ASCII files to drive CR electronic machines;
    advise me to this email: [email protected]
    Waiting for your advise.
    Kind regards,
    Fabrizio.
  16. #36
    May 2012
    Winplasma on Cr electronocs
    We have a CR Electronics Plasma table that was purchased used. The model is 1999 and is using winplasma version 4.0. We need to update the PC and reinstall winplasma but do not have the key and would like to update the version.
    Where do i go to talk with someone about my options with the software, I am desperatly trying to find a source for this information??
  17. #37
    Aug 2008
    21
    Wincam/Winplasma cr electronic support
    Hello blastrac,
    no problem! I have worked for years in CR electronic and I know very well
    the programs Wincam / Winplasma.
    I can supply you updated programs with USB keys in order to work even under windows xp/vista/w7.
    I have developed several solutions to satisfy the customer requirements;
    those solutions are different and let also interfaces with other cad-cam programs, post processors for other machines or update of software with USB dongle.
    Please mail me to [email protected]
    I will be happy to let you to know all solutions in order you could choose the best one
    for your needs.
    Kind regards,
    Fabrizio.
  18. #38
    Sep 2017
    Re: CR Electronic HD Plasma - Winplasma
    Hello, I have CR Electronic eu 3-15hd 2002 hypertherm3070, but no instructions on how to connect and operate. Please help with finding a manual for this machine.
  19. #39
    Aug 2008
    21
    Hello,
    I am able to provide full support on software point of view, mainly on software Winplasma/Wincam/P2 of CR electronic machines. For support on machine itself, mechanic issue and or electronic I have service contacts I work with.
    They can support you.
    Just let me know your needs. Feel free to contact to [email protected]
  20. #40
    Mar 2018
    [QUOTE=donaldooo;456880]
    Quote Originally Posted by cweimaraner View Post
    Hi, we recently bought an Cr electronic CNC plasmacutter, with the hypertherm HD3070. In about 2 weeks we have the machine installed on our location. The machine contains the original software/manuals, with cds included. So maybe I can help you. I understand that you only need the original CNC programming software?
    Kind regards.
    Donny
    Hello Donny,
    I found your above message.
    I have the same problem with the same machine CR ELECTRONIC hd 3070. I need the phoenix software created by CR ELECTRONIC as a original one. I would like to reinstall it due to some problem with the existing one in the machine. Please can you tell me if you have this programm
    Thanks in advance
    Ngz
Page 2 of 3 123
  1. CR Electronic
    By blahic11 in forum European Club House
    Last Post: 11-20-2011, 12:31 AM
  2. CR Electronic Plasma Cutting Machine
    By Joao_correia in forum Waterjet General Topics
    Last Post: 11-20-2011, 12:22 AM
  3. CR ELECTRONIC PLASMA MACHINE "software"
    By mcsales in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 09-08-2011, 08:11 PM
  4. CR Electronic HD Plasma - Winplasma converter
    By FabrizioIT in forum Waterjet General Topics
    Last Post: 01-27-2009, 09:56 AM
  5. '06 Electronic setup?
    By bkboggy in forum Joes CNC Model 2006
    Last Post: 01-26-2009, 06:04 PM
