Got me beat there, C1. I finally got down to B&B and got the bed steel .. theorhetical weight will be 185.22 lbs. That is 2 ea 1/4" x 3 1/2" crs by 108", 2 ea 2" x 1 1/2" .120 rectangular tubing by 108", and seven pieces of 2" x 1 1/2" by .120 wall rectangular tubing by 54". 24' of the 1/4" and 60' of the tubing cost $282.52 fob ukiah .. plus cut charge and tax.
My 200 lbs for this smaller 3' x 4' machine includes the Z axis weight without the router, so we're probably running about the same at the moment, though it sounds like you are building a larger machine. My 12' long machine used 1x2x.120" box tubing. I didn't keep track of the component part weight during that frame build. The third revision of the gantry has been weighed at 185 pounds with M12VC router.
All your grief with bowing in yur channel build was not lost on me C1. Seven ribs .. precision machined to length, 14 new Kant-twists, and 7 new Pony clamps, should keep this puppy locked solidly in place for tacking and welding .. one would hope. Yeah .. the darn clamps cost more than the steel .. but .. you can never have too may clamps in the shop, right? Once inspired to build in steel, I am comitted to embrace every advantage, and welding up the bed is certainly most critical.
Not having at least one rib in the middle and overtightening the bar clamps was probably causing my problem with bowing. Just bad procedure on my part.
Umm .. seven ribs may be overkill, but my neighbor .. EX as well, asked me if it could do marble, so I went back to the seven rib design. The mass of 85 square feet of 3/4" mdf glued to a seven rib bed should be pretty darn stable, as far as the bed is concerned.
Do I hear CNC gravestone/monument carving? Will have to look that up to see if it's commonly done. The dust would be nasty stuff to deal with.
The bed will be gimbled for welding .. two pieces of like 3/4" crs round through the end ribs, and one wall of ribs 2 and 6. I am not a welder .. get by with 6013 or 7018 for tractor stuff. Got some .030 and tips for the Millermatic 180. Probably mount indicators to compensate for sag in the vertical position.
I have an 10 year old Miller 175. Does everything I ever needed.
I am using .120 wall here, and while I acknowledge your admonishments regarding welding the rails onto the bed, I am still inclined to follow that plan, dependant on the accuracy of the bed upon welding completion.
As to your new 3/16" wall construction, I do suggest you use "Rollers" for the threading .. roll forming taps. The metal is actually roll-formed into threads, swaging the grain of the material to conform to the thread form, rather than inturupting the material grain. Also .. use class 3 taps and hardware .. closer tolerance. A slight 120 degree c-sink helps the lead .. the drill size is more critcal for rolling threads, and moly type tapping fluid is about as good as it gets. I've rolled 0-80 threads in 304 .. it works .. and no damn chips ... hehehe. The slight extrusion created, depending on your depth of c-sink (keep at a minimum) can be easily flatened with a mill file.
I haven't tried those taps yet. Will see about getting some of the common sizes I use. If they will also break, I'm up to the job.
Have Fun .. Be Safe :-)
