Thanks for your interest.
The finishing method used for the above 2 desk names results in a very attractive surface, although it reflects light & will not photograph well at all.
A fine disk is used to polish, followed by adding swirl marks with the edge of a 4" coarse grinding disk.
This is followed by clear or translucent coloured lacquer which enhances the swirl effect.
Weldtutor..
I am really impressed for the Flame sign... Whenever i saw your new work i am mesmerized..
http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/
http://my-diysolarwind.blogspot.com/
How Can i use a hand torch in (LGK8-100) cut throgh 20mm. in acnc table. pls. any help for that ?
call me at
0101405249
or
0117080734
mohamed alhawary
Cell will not connect to that #.
Six plus years & this table, with chain drives, continues to produce high quality results. :banana:
Large dolphins are 22" long & smaller ones are 1/2 scale.
Files are modified versions of downloads.
Thanks God ou are alive again. Nice work as usual? Where were you by the way?
Hello Weldtutor, very very good post, I think I didn't read al the comments, maybe is a subject you talked in some of the comments, but could you tell me wich software coul be used to control the table ?
thanks
Hi MecatronicsBoy,
Welcome to CNC Zone!:wave:
The software used to control the plasma table is MACH 3.
WT
Hello Weldtutor and fellow Canuck. (although I now live in the US) :-) Do the torch plate bearings actually ride on the work?
Thank you
Tom
Hi Tom,
Yes, the transfer bearings on the underside of the torch plate do actually ride on the work surface.
This works quite well & in posts #184 & 281 there is additional information you might find helpful.
Pictures in posts #48, 112, 285, & 363 also show the torch plate & bearings.
The springs on the plate mounting bolts compensate for work surface irregularities.
WT
